Does the RV016 port forwarding bypass firewall default rules?
brunomoyle
Hello everyone, this is my first discussion within this community (I think) and I got a strange issue when opening SSH service to a Database Administrator within my LAN, that has a RV016 as the default gateway. So confidence, I just set up a port forwarding in Setup > Forwarding and everything works fine, cool.
However, I do not want this to be a public access, I need a specific firewall rule for a specific external IP address (only the DBA fixed IP Internet might connect to my database server through SSH).
O noticed that when a port forwarding is created within RV016, it bypass the firewall default rules and wide-opens the service (port) to the web. Conceptually, this is correct, as port forwarding is a network translation, but I expected that my firewall had work over this.
My current solution was to create a "Deny from all" rule at port 22 and then create one additional rule that allows traffic from an specific IP at port 22.
Any help?
Thanks!
paolo bevilacqua
Please post in SBCS as the RV is not an enterprise Cisco product.
  1. What's SBCS?
  2. I get here by Cisco Support Community > NetPro > Network Infrastructure > WAN, Routing and Switching. Where did I got wrong?
Thanks.
Hi Bruno,
Paolo is referring to this:
Cisco Support Community > NetPro >Small Business Support Community
