Domain server problem
jackie_gx
ping http://www.google.com
Translating "www.google.com"...domain server (xxx.xxx.xxx.xxx) [OK]
Sending 5, 100-byte ICMP Echos to 203.106.203.238, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 m
this is a Cisco 7206VXR using c7200-p-mz.124-12.bin. When ping to http://www.google.com, the domain server translation repeat appeared few times. It suppose to be appear one time only, right? Do you guy have any idea what cause it?
5 Replies 5
guruprasadr
Level 7
Level 7
HI Jackie,
This is Normal. Refer the"show run" whether the domain name-lookup is configured for some Servers then it may resolve quickly.
Otherwise check with the ISP for some DNS Names.
Do Rate if HELPS
Best Regards,
Guru Prasad R
ya,the domain name-lookup is configured, the config is
ip domain name xx.xx.x
ip name-server xxx.xxx.xxx.xxx
but on the other router also the domain name-lookup is configured, the config is
ip domain name xx.xxx.xx
but whe ping www.google.com it appear
ping www.google.com the domain translation is just appear 1 time only. And why it repeat several time on the other router
Translating "www.google.com"...domain server (202.188.1.5) [OK]
Sending 5, 100-byte ICMP Echos to 64.233.189.104, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/60 ms
HI Jackie,
If the name Server located in Service Provider means, i would recommend check with them for Resolution.
Whether the lookup Servers are Primary or relay points.
Try to trace the name Server from the Router in which you have the Problem and from the other U dont have.
Do Rate if HELPS
Best Regards,
Guru Prasad R
hi Guru Prasad R
thanks for the reply
but I do not understand the meaning of "Resolution" and what is the look servers?
hi Guru Prasad R
but I do not understand the meaning of "Resolution" and what is the "lookup servers"?
