dot1q trunk
suthomas1
Level 7
Level 7
Good day all,
We have an old cisco 880 series router that is being used at one of our small offices to act as wan router.
This router has port fa1 which connects to a cisco layer2 switch & vlan1 on this router provides connection to the office.
interface FastEthernet1
description local office switch
switchport mode trunk
no ip address
interface Vlan1
ip address 192.168.101.1 255.255.255.0
ip helper-address 10.58.0.1
no ip redirects
All this works fine so far. we want to add more ip subnets to this, we were hoping to use dot1q on fa1 interface & create int fa1.51 (where 51 will be vlan51 layer3 on this router).
But that doesn't seem to be possible, i just tried the below on a spare interface on the same router but it doesn't accept it?
(config)#int fa2.52
% Invalid input detected at '^' marker.
Is this router not supporting dot1q or do i have to create rest of the ip subnets (eg. vlan51,52 as layer3) on this router and then create layer2 on connected switch with int fa1 passing all these vlans as trunk towards the office network & allow us to put users on new vlans?
Please help.
11 Replies 11
Jon Marshall
Yes.
Jon
Thanks for the quick response.
So can i do not need to change anything on the switch facing port of 880 router (as below)?
no ip address
Any new vlans created on the 880 router (eg. vlan 52-192.168.10.1/24) should be able to pass through fa1 port towards the layer 2 switch? Also, because users are already using this router .... we creating these additional vlans and it going via the trunk , will it cause any disruptions to traffic?
do we need it have a local console to do this or is it safe to do it over remote ssh?
Trunk will allow all the VLAN, if you like to add more later, it give ability add directly.
Make sure your router has sub interface for that VLAN to support dot1q.
Since you are going to change the Link where you connected, suggest to ask local help or if not possible, do reload command 5min, in case go wrong, it will reload and come back known good config. (in case)
BB
Hello @suthomas1 ,
if you now are using Vlan 1 both on the Cisco 800 router and on the downstream switch you shoud  have no issues.
Remember that you need to move to trunk mode on both sides router and switch but this can be done safely,
Remember also that for each new VLAN you create on C 800 you need to create the same L2 VLAN number  on the switch.
Access ports for these new VLANs on the switch  will need
switchport access vlan X
If you have a VLan mismatch on current link between C880 and switch you need more care and may be someone on place to move the management address of the switch to Vlan 1.
Hope to help
Giuseppe
Leo Laohoo
800-series router do not support sub-interfaces and only have limited amount of VLANs allowed.
If I remembered correctly 880 only supports up to 5 or 7 EIGHT (8) VLANs and the 890 supports up to 10 25 VLANs.
Sorry, lost track of this.
Reading it again, there should not be an issue with adding more layer 3 vlans on the cisco 880?
Currently there is only one layer3 vlan1, planning to add another 4 with different ip ranges & then also creating the same 4 vlans on the switch...that should not be a problem i think. Appreciate all inputs.
Thanks for the responses.
So two additional layer 3 vlans were configured on the 880 series router, it all works fine with layer 2 on the switch.
However, it had vlan1 with an ip address that was used for remotely connecting to the router.
While trying to delete this vlan1 from router, it gave an error on the lines of "default vlan can not be removed".
ideally i want to remove vlan1 and use one of the other new vlans to remote access this router.
How can i safely remove this vlan1 from router, without causing any disruption to either remotely accessing the router or any impact to users?
!!current config on router!!
interface FastEthernet2
description layer2 switch
no ip address
interface Vlan1
ip address 10.41.1.1 255.255.255.0
sh int fa2 trunk
Port Mode Encapsulation Status Native vlan
Fa2 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa2 1-4094
Port Vlans allowed and active in management domain
Fa2 1,24,58,81
Port Vlans in spanning tree forwarding state and not pruned
Fa2 1,24,58,81
!!current config on switch!!
interface GigabitEthernet0/48
description 880 router
speed 100
interface Vlan1
ip address 10.41.1.2 255.255.255.0
sh int gi0/48 trunk
Gi0/48 on 802.1q trunking 1
Gi0/48 1-4094
Gi0/48 1,24,58,81
Gi0/48 1,24,58,81
VLAN 1 can never be removed.
Can it be stripped of ip address on vlan1 interface & shut down safely?
Yes.  It is very common practice.
