Doubt - VRF with static route.
conectividade
Messrs, I'd like your help! I've been trying to do a VRF config, and its doesn't work. We need to access the net 10.1.2.4/30 comes from 10.1.11.0/24 and 10.1.14.0/24. what is wrong? what is missing? Attached we have net and cfg. Thanks, Renato
Renato,
First off,you have to make sure that what the routing table of VRF_MFrame looks like. It will reveal what you have missed. Just do a "sh ip route vrf Mframe" command. (grin)
int vla 10 & int vla 14
ip vrf forwarding Mframe
ip route vrf Mframe 10.1.11.0 255.255.255.0 10.1.10.1
HTH,
Toshi
Toshi, my bad!
I cuted the wrong part of cfg. I rewrited the net and cfg with your help, please look this again.
thanks a lot, Renato.
Renato,
Interface Vlan 14 is the connected interface on the VRF switch. No need to have a static route on it. Just remove it.
no ip route vrf Mframe 10.1.14.0 255.255.255.0 10.1.10.1
Like previously posted,let's try to do a "sh ip route vrf Mframe" command.
HTH,
Toshi
Toshi, thanks a lot!
Now, that cfg is working.
thanks,
Renato
