dowload IOS into Cisco 891 without ROMMON
ha@profindis.de
I have formatted the flash and rebooted the router C891F . The PASSWORD RECOVERY FUNCTIONALITY IS DISABLED, so that I cannot press the reset button.
I have copied the valid on the usb and conneted it to the router but it was not working. i receive the same outout:
System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 2014 by cisco Systems, Inc.
Total memory size = 512 MB
Field Upgradeable ROMMON Integrity test
_______________________________________
ROM: Digitally Signed Production Software
C891F-K9 platform with 524288 Kbytes of main memory
Main memory is configured to 32 bit mode
Upgrade ROMMON initialized
boot: cannot determine first executable file name ondevice "flash:"
would you help me please?
15 Replies 15
Leo Laohoo
If the IOS is in the USB then use the command "boot usbflash0:".
Hi, the problem i have is. I can not go into the ROMMON. Send Break is not working
try to erase config by sending multiple break signal on boot. See below page:
http://packetlife.net/blog/2010/oct/11/recovering-no-service-password-recovery-service/
After it, I thing that next-reload will cause going to ROMMON, because startupconfig is empty and password recovery is enabled by default. At the final step recover IOS via USB (if available) or TFTP in ROMMON.
HTH,
What terminal are you using?
Try another one...
Show all the messages from terminal.
Hi, I use teraterm and putty. only this message will be displayed on the terminal (the same message almost the time) :
let's try...
connect console cable into the console port
set speed 300
reboot the router
wait 2 min
change speed to 9600
press "enter"
what will you get?
Hi, i receive the same message:
ÐÁÓÓ×ÏÒÄ ÒÅÃÏÖÅÒÙ ÆÕÎÃÔÉÏÎÁÌÉÔÙ ÉÓ ÄÉÓÁÂÌÅÄ
Hold on ... What are you trying to do?
Do you have the ROMmon prompt?
I try to get the ROMmon prompt. This is not possible.
Do you have another working C891F-K9?
yes
try to find usb flash for 128Mb, 256Mb of 1Gb
inset it in a working 891, format, copy working image to usbflash.
Insert usbflash into Cisco 891 and try to boot it...
it was not working. The router only running in the same loop: Starting again without any break.
Thank you for helping.
