drops in queue on subinterface with out congestion (QOS)
Hello colleagues
The problem is, that i have ~ 7-8 Mbps on 65Mbps link, but my service policy seems to drop packets according to queue size.
In my understanding, policy map start to drop traffic only when congestion appear, is it so?
same situation on ASR 1002 and 7206
ios  Version 15.2(4)S4 and  Version 15.1(4)M7
Here is config for policy map on WAN link
class-map CRITICAL
match precedence 5
class-map match-any IMPORTANT
match precedence 3
match precedence 6
class-map BUSSINESS
match precedence 1
policy-map SHAPING
class class-default
  shape average 65000000
  service-policy SP-QOS
policy-map SP-QOS
Class CRITICAL
priority percent 70
Class IMPORTANT
bandwidth percent 12
Class BUSSINESS
random-detect dscp-based
Class class-default
bandwidth percent 6
random-detect
interface GigabitEthernet0/0/1.9
encapsulation dot1Q 9
 ip address xxxxxxxxx
 ip nat outside
 ip nbar protocol-discovery
service-policy output SHAPING
and here, what I see in statistic
  Service-policy output: SHAPING
    Class-map: class-default (match-any)
      129798770 packets, 40181696005 bytes
      5 minute offered rate 7304000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 270 packets
      (queue depth/total drops/no-buffer drops) 0/11680/0
      (pkts output/bytes output) 129779213/40165064207
      shape (average) cir 65000000, bc 260000, be 260000
      target shape rate 65000000
      Service-policy : SP-QOS
        queue stats for all priority classes:
          Queueing
          queue limit 512 packets
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 13484092/3912327041
        Class-map: CRITICAL (match-all)
          13480980 packets, 3911647909 bytes
          5 minute offered rate 422000 bps, drop rate 0000 bps
          Match:  precedence 5
          Priority: 70% (45500 kbps), burst bytes 1137500, b/w exceed drops: 0
        Class-map: IMPORTANT (match-any)
          7721261 packets, 1021340017 bytes
          5 minute offered rate 108000 bps, drop rate 0000 bps
          Match:  precedence 3
          Match:  precedence 6
          Queueing
          queue limit 64 packets
          (pkts output/bytes output) 7715467/1020879486
          bandwidth 12% (7800 kbps)
        Class-map: BUSSINESS (match-all)
          47724414 packets, 15630803933 bytes
          5 minute offered rate 3393000 bps, drop rate 0000 bps
          Match:  precedence 1
          Queueing
          (queue depth/total drops/no-buffer drops) 0/7388/0
          (pkts output/bytes output) 47741826/15628877447
            Exp-weight-constant: 4 (1/16)
            Mean queue depth: 1 packets
            dscp       Transmitted         Random drop      Tail drop          Minimum        Maximum     Mark
                    pkts/bytes            pkts/bytes       pkts/bytes          thresh         thresh     prob
            af11     2990415/861605540      25/32285        645/884994            28            32  1/10
            af12      677310/367870926       0/0             10/5466              24            32  1/10
            af13      154681/48657019        3/1634           4/307               20            32  1/10
          60817716 packets, 19603759092 bytes
          5 minute offered rate 3363000 bps, drop rate 0000 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops) 0/4292/0
          (pkts output/bytes output) 60837828/19602980233
          bandwidth 6% (3900 kbps)
            class       Transmitted         Random drop      Tail drop          Minimum        Maximum     Mark
            0         3474437/1110326227    269/276936       742/851882            16            32  1/10
            1               0/0               0/0              0/0                 18            32  1/10
            2               0/0               0/0              0/0                 20            32  1/10
            3               0/0               0/0              0/0                 22            32  1/10
            4               0/0               0/0              0/0                 24            32  1/10
            5               0/0               0/0              0/0                 26            32  1/10
            6               0/0               0/0              0/0                 28            32  1/10
            7               0/0               0/0              0/0                 30            32  1/10
26 Replies 26
Joseph, thanks a lot for your help!
I have only "QoS-FE:Implemeniting..." course as a background for QoS methods, and it was clear for me. But after your comments, i`ve understand, that sky is not so clean as i thought :) May be you can advice some helpfull material for deeper understanding (i`m now reading "IP Quality of Service [Srinivas Raju Vegesna]", but may be you can advice some thing more)?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unfortunately, I've never come across any really, really good source material that explained how to effectively use QoS in a production environment with real traffic.
Even simple "gotchas" like Cisco interface FIFO queue depth (tx-ring-limit) may need to be adjusted to meet QoS goals, but that's often overlooked.
I'll admit, when I first encountered WRED, I thought it was such a great idea (and in someways it still is), but nothing I initially read mentioned all the issues with it.  (Oh, and again, don't misunderstand, it can be useful, but it's a tricky technology to really obtain its best.)
Or, on WRED, besides the most obvious adjustment of min and max thresholds, when should the moving average parameter be adjusted.  Or, is 10% really the ideal value for the random drop percentage?
Did your course discuss those?  (If not, that's not a knock against your course, it's just determining the correct values for all RED parameters is difficult.)
Anyway, all I can suggest, if you really want to understand QoS, is read a lot.  Take any one source with a grain of salt.  Read research about "improved" versions of QoS approaches, especially taking note of what's the problem or issue trying to be solved (sometimes more interesting then their proposed gee-wiz solution).
Monitor you results and don't be afraid to adjust, but also be prepared for making things worse.  ;)
yep, we discuss it :) actually - a lot of interesting information about qos tuning was on this course. But not so much practice on real WAN in my case. But, as for me - it`s very interesting to work on network improvement!
One more time - thank you for your help, time and good advices!
Have a nice day! :)
Akash Agrawal
In this case i see two issues and few config tweaking can help us here. In case of shaping, packet gets queued only when traffic is crossing conform rate(packets (bits) arrived in Tc interval is more than Bc defined). Shaping rate of 65 mb for 1 sec is too high and we have very less traffic on the link but to check whether traffic conforming traffic contract or not, shaping tool uses Token bucket mechanism and in every Tc time interval it replenishes Bc amount of token. Here Bc is set very low which is just 260000 bits and if you calculate Tc it is 4 ms.
Bc = 260000 bits
CIR = 65000000 bits/sec
Tc = Bc/CIR = 260000/65000000
Tc = 4 ms
So every 4 ms, bucket will be filled with 260000 tokens. If within 4 ms router gets 21 packets (1500 bytes) so all tokens will be used and next packet will be queued in the respective queue. So for bursty traffic we may see queue getting filled for short duration and WRED is getting triggered. Probably it is happening for class BUSINESS and class-default.
Even for latency/jitter sensitive traffic Tc is recommended as 10ms or by default it gets calculated as 25ms. You can try below values of Bc and Be for respective Tc.
Tc = 25 ms ---> Bc = 1625000 , Be = 1625000
Tc = 10 ms ---> Bc = 650000 , Be = 650000
Second thing queue-limit for each class is 64 packets, but WRED minimum threshold is set as 16 and maximum as 32. If changing Bc,Be does not help then WRED threshold needs to be increased.
Please do not forget to rate helpful post.
-Akash
Thank you Akash!
for your first suggestion - i belive this could happen, if we have a lot of burst traffic. But on monitoring systems, i didn`t see any splashes (30s check rate). May be this burst traffic lasts not too long and i didn`t see it on monitoring...
I`ll try to set 10ms Tc, and will see what happened.
second suggestion - i think you right. That was my confusion, couse i forget the way how WRED works.
Thank you for your help!
still  see some tail drops in class-default (current Bc is 1625000)
      621651 packets, 242393853 bytes
      5 minute offered rate 4862000 bps, drop rate 0000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/159/0
      (pkts output/bytes output) 621463/242224044
      shape (average) cir 65000000, bc 1625000, be 1625000
          Queueing
          (pkts output/bytes output) 26105/5613542
          26105 packets, 5613542 bytes
          5 minute offered rate 116000 bps, drop rate 0000 bps
          Match:  precedence 5
          17897 packets, 1842729 bytes
          5 minute offered rate 41000 bps, drop rate 0000 bps
          Match:  precedence 3
          Match:  precedence 6
          Queueing
          (pkts output/bytes output) 17881/1841225
          204242 packets, 55251009 bytes
          5 minute offered rate 1112000 bps, drop rate 0000 bps
          Match:  precedence 1
          Queueing
          (pkts output/bytes output) 204242/55251009
            af11      171891/43885889        0/0              0/0                 28            32  1/10
            af12       24896/6077339         0/0              0/0                 24            32  1/10
            af13        7455/5287781         0/0              0/0                 20            32  1/10
          373394 packets, 179683059 bytes
          5 minute offered rate 3607000 bps, drop rate 0000 bps
          Match: any
          Queueing
          (pkts output/bytes output) 373235/179518268
            0          373227/179516812      47/51277        112/113514            16            32  1/10
            4               8/1456            0/0              0/0                 24            32  1/10
As I mentioned before, please try to increase WRED minimum,maximum threshold. right now it is 16 32, you may increase it to 32 48.
Done, cleared statistic - get TailDrop hit in a first few seconds sad
          60351 packets, 22005334 bytes
          5 minute offered rate 559000 bps, drop rate 0000 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops) 0/4/0
          (pkts output/bytes output) 60347/22003490
            0           60345/22003126        3/1774           1/70                32            48  1/10
            4               2/364             0/0              0/0                 24            32  1/10
If you see number of drops have been reduced significantly. Earlier there were 159 drops (random + tail) in total 373227 transmitted packets which means 1 drop out of 2347 packets. Now it is 1 drop out of 15086 packets. So drop rate has been reduced by 6 times. If you want to reduce drop further, need to increase WRED threshold more.  If you have bursty traffic in network, you need to have larger queue to hold the bursty traffic.
i`ve checked my first post statistic for Tail Drop -
So it about 1 of 12916 packet drop rate
today statistic
            0        32108690/9746181825    895/1117314     3940/4774446           32            48  1/10
So it about 1 of 8149 packet is Tail droped.
I`ll try to set thresh a little bit larger, but don`t look like it helpes a lot.
Maybe set Bc larger?
Definitely you can try with increasing Bc. However would like to share below info related to WRED max threshold in HQF IOS.
The IOS you are using, i guess HQF is implemented and in HQF queue-limit of each class takes precedence over max-threshold of the WRED unlike in pre-HQF images. By default class queue-limit is 64 so WRED threshold can not be exceed more than the queue-limit(64). If you want to increase WRED max threshold more than 64 then queue-limit also needs to be increased. You can try to increase queue-limit to 1000 and WRED also as min-600 ,max-1000. Just for testing.
thanks, i`ll try!
