DS3 Connection
angel-moon
Level 3
Level 3
Hello Everyone,
with an NM-1T3/E3 Netowkr module other than issuing the card type command, assiging an IP address and issuing the no shut command on the now created Serial interface is there anything else that needs to be done to bring up a DS3 connection?
Thanks in advance! ALl replies rated
Collin Clark
The DSU bandwidth and framing are critical. Here's an exmaple of my interface config.
interface Serial2/0
description [Circuit ID]
ip address a.b.c.d 255.255.255.252
no ip proxy-arp
encapsulation ppp
ip route-cache flow
ntp disable
dsu bandwidth 40300
framing c-bit
cablelength 250
serial restart-delay 0
no cdp enable
Hope that helps.
