DSL backup for T1 problem
prafuljaded
Level 3
Level 3
My network has a T1 primary with DSL backup.T1 is on serial0/0 and DSL is ethernet1/0.
When T1 goes down,DSL doesn't kick off and I lose IPSec connectivity to this router LAN.
Should I be adding a statement
'ip nat inside source route-map nonat pool dsl overload' to the below config. Can anyone verify it. Cant get the T1 down during these hours
Config:
version 12.3
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname router
boot-start-marker
boot-end-marker
logging buffered 12000 debugging
enable secret 5 xxxx
username router password 7 xxxx
memory-size iomem 20
clock timezone central -6
no aaa new-model
ip subnet-zero
no ip domain lookup
ip name-server 21x.x.x.x
ip name-server 21x.x.x.y
ip cef
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key #### 65.x.x.1
crypto ipsec security-association lifetime seconds 120
crypto ipsec transform-set cm-transformset-1 esp-3des esp-sha-hmac
crypto map cm 1 ipsec-isakmp
set peer 65.x.x.1
set transform-set cm-transformset-1
match address 120
interface FastEthernet0/0
ip address 192.168.148.254 255.255.255.0
ip helper-address 192.168.x.x
ip helper-address 192.168.y.y
ip nat inside
speed auto
full-duplex
interface Serial0/0
ip address 10.1.x.x.255.255.252
ip nat outside
no fair-queue
service-module t1 remote-alarm-enable
crypto map cm
ip rtp header-compression
interface Ethernet1/0
ip address 20.1.1.x.x.255.248
ip nat outside
half-duplex
crypto map cm
router eigrp 1
redistribute connected
passive-interface FastEthernet0/0
network 192.168.148.0
network 192.168.251.0
auto-summary
no eigrp log-neighbor-changes
ip nat pool branch 10.1.1.1 10.1.1.1 netmask 255.255.255.252
ip nat pool dsl 20.1.x.x.1.1.1 netmask 255.255.255.248
ip nat inside source route-map nonat pool branch overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
ip route 0.0.0.0 0.0.0.0 e1/0 130
access-list 120 permit ip 192.168.148.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 130 deny ip 192.168.148.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 130 permit ip 192.168.148.0 0.0.0.255 any
route-map nonat permit 10
match ip address 130
Praful
thisisshanky
Level 11
Level 11
NAT is required only for communication from the LAN side of the router to the internet side. The problem, that IPSEC could be dropping here is because of crypto map configuration error. This is a LAN2LAN tunnel, so peer addresses have to be defined. On the remote side you would have set the peer address to be 10.1.1.1 (serial0 ip address), but when T1 goes down, the tunnel needs to be reestablished to 20.1.1.1. For this to happen you should have two crypto maps at the remote side as well as two isakmp peers set for 10.1.1.1 and 20.1.1.1. Have you verified whether this has been configured ?
For inside to outside access (for hosts) make sure
you configure two nat inside source commands with each pool. Check NAT with route-maps in this link
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanx Shankar.I have a PIX on the other end and have all the configs as below working fine I guess I can think of.
crypto map xxx 2 ipsec-isakmp
crypto map xxx 2 match address xxx051
crypto map xxx 2 set peer 10.1.1.1
crypto map xxx 2 set peer 20.1.1.1
crypto map xxx 2 set transform-set tripledes
crypto map xxx 2 set security-association lifetime seconds 120 kilobytes 4608000
crypto map xxx interface outside
crypto ipsec transform-set tripledes esp-3des esp-sha-hmac
sysopt connection permit-ipsec
access-list xxx051 permit ip 192.168.0.0 255.255.0.0 192.168.148.0 255.255.255.0
access-list nonat permit ip 192.168.0.0 255.255.0.0 192.168.148.0 255.255.255.0
isakmp key xxx address 10.1.1.1 netmask 255.255.255.255 no-xauth no-config-mode
isakmp key xxx address 20.1.1.1 netmask 255.255.255.255 no-xauth no-config-mode
isakmp enable outside
isakmp identity address
nat (inside) 0 access-list nonat
nat (inside) 1 0.x.x.x.0.0.0 0 0
Praful
Praful,
Can you get a debug output "debug crypto isakmp" when the T1 fails and the IPSEC tries to establish over the DSL tunnel. (Do the debugs during off peak hours). Also have you tried configuring two seperate instance of the crypto map on the pix with individual set peer commands ?
Sankar.
Sankar Nair
