DSL Configuration on SBC Global / ATT PPPoE need help
bill.morton
I am trying to get PPPoE DSL setup on a 2811 with SBC Global Internet and I am having some issues. I followed a configuration that was posted and everything worked and came up with full L3 connectivity to the internet until I did a reload on the router.
Upon Reload I get the following message about every second:
000066: *Jun 6 16:02:05.791 CDT: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
000067: *Jun 6 16:02:05.795 CDT: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
000068: *Jun 6 16:02:09.679 CDT: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
000069: *Jun 6 16:02:09.683 CDT: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
I must be missing something very simple, and ATT/SBC reps are trying to play the 'we dont support that router' game. Any help much appreciated, and points awarded.
Current Config (the relevant parts):
2811-2#sh run
Building configuration...
Current configuration : 9313 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname 2811-2
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 4096 debugging
no aaa new-model
resource policy
clock timezone CST -6
clock summer-time CDT recurring
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
no ip bootp server
ip ssh time-out 60
ip ssh authentication-retries 2
login block-for 10 attempts 4 within 3
vpdn enable
vpdn-group ppoe
request-dialin
protocol l2tp ! The guide I had put "pppoe" here which was not an option. I tried both l2tp & l2
crypto pki trustpoint TP-self-signed-
interface FastEthernet0/0
description Link to the LAN 192.168.1.0/24
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
duplex auto
speed auto
no mop enabled
glbp 50 ip 192.168.1.3
glbp 50 timers 5 18
glbp 50 priority 10
glbp 50 preempt delay minimum 30
glbp 50 load-balancing host-dependent
glbp 50 authentication md5 key-string 7 xxxxx
interface FastEthernet0/1
Shutdown
--More-- no mop enabled
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0/0/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address x.x.x.201 255.255.255.248 !yes this is the static block.
no ip redirects
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxx@sbcglobal.net
ppp chap password 7 xxxxxx
ppp pap sent-username xxxx.net password 7 xxxxx
router eigrp 10
passive-interface ATM0/0/0
network 192.168.1.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 x.x.x.206 !ISP Router
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 10 interface Dialer1 overload
no cdp run
control-plane
line con 0
exec-timeout 60 0
logging synchronous
login local
transport output telnet
line aux 0
line vty 0 4
login local
length 0
transport input telnet ssh
line vty 5 15
privilege level 15
login local
access-list 10 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
scheduler allocate 20000 1000
sntp server 129.6.15.28
end
Hi, please send output of "show dsl interface", "debug ppp negotiation" "debug ppp autentication" with "term mon"
6 Replies 6
bill.morton
See previous message for full description & config.
-------------- Dialer Int when no dsl:
2811-2#sh int dialer 1
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address is x.x.x.201/29
MTU 1492 bytes, BW 56 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 01:13:42
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
1012 packets input, 83773 bytes
1113 packets output, 96320 bytes
=) Thanks! That actually solved my issue ... when I saw the debug ppp authentication and the string was xxx2sbcglobal.net instead of xx@sbcglobal.net I was able to solve the problem right away. Points!
Good. Also note:
vpdn enable
vpdn-group ppoe
request-dialin
None of the above is needed, whatever the guide says.
interface ATM0/0/0
bundle-enable
That doesn't do anything
that is better set to itu
hold-queue 224 in
Really no need to increase input queue
interface Dialer1
dialer-group 1
PPPoE doesn't need dialer-group. Connection is always open.
router eigrp 10
That interface is not IP-enable, no need to make it passive.
Alternative to that, use "ppp ipcp default router" under dialer
Thanks for the appreciation and good luck!
Thanks again!
I took all of your suggestions except for dsl operating-mode and default route since I have a static block to work with.
I am sure that I will come up with a few more questions, but it is great to have so many professionals that are willing to help out! I'll make sure to scan the forms a bit to return the favor.
No worries, in networking (almost) everything has an explanation.
"dsl operating-mode" doesn't have perceptible differences except the router never attempts the legacy ANSI ADSL modulation that is not used anymore.
"ppp ipcp default route" installs the default route via PPPoE once established, no difference if you have a block or not. Really a matter of "being clean" more than anything else.
On the matter of having a static block, most likely you will use the additional addresses to route them (with NAT or without) to inside devices. Certainly you don't want them be routed back toward the PPP link, like your configuration does currently.
