DSR & CTS down
RAGHU N
Hi all while executing Show int command on one of our remote site , seems Data Set Ready and Clear To Send are on down state , as shown below.......
Serial0/1/0 is up, line protocol is up
  Hardware is GT96K Serial
  Backup interface Dialer1, failure delay 0 sec, secondary disable delay 60 sec,
  kickin load not set, kickout load not set
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 15/255, rxload 7/255
  Encapsulation PPP, LCP Open, multilink Open
  Link is a member of Multilink bundle Multilink1, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w4d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 3 packets/sec
  5 minute output rate 4000 bits/sec, 7 packets/sec
     4797364 packets input, 390759527 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     16 input errors, 16 CRC, 2 frame, 0 overrun, 0 ignored, 4 abort
     2951233 packets output, 200799167 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=down  DTR=up  RTS=up  CTS=down
what may be the causes for this , as remote site doen't have any connectivity issues .
Thanks & Regards,
Ram
Richard Burts
Ram
There might be several things that could explain what you are seeing and the lack of impact.
- I see that this interface is a member of a multilink  bundle. It is possible that the other members of the multilink are carrying traffic and that is why the remote site is not experiencing connectivity issues.
- we do not know what is physically connected there and whether that device generates DSR or CTS or not. Is it possible that the device does not generate these signals and works normally without them?
- we do not know how the interface is configured and whether there might be something in the config that could help to explain what is going on. Perhaps you can post the config of the interface.
- the fact that it shows line is up and line protocol is up seem to indicate that the interface is operating ok. If you do a show interface, wait a bit, then do another show interface are the counters of packets going in and going out increasing?
Rick
Rick
Hi Rick .....
-well . actually its a DTE site and we use V.35 interface standard and use Smart Serial .
We have DCE which is a Telco Operator .
-Its a part of Multilink bundle . But its other member is none other than a virtual  Multilink interface .
-Packets are  flowing as usual.
-Actually if a DTE is connected to DCE and DCE is working fine . then both DSR and CTS must be Up ??
- these are our serilal and multilink conf templates :
interface Serial0/1/0
backup delay 0 60
backup interface Dialer1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
ppp multilink group 1
crypto map **
interface Multilink1
ip address *****************
no ip redirects
no ip proxy-arp
ip ospf authentication message-digest
ip ospf message-digest-key 156 md5 7 0337594A250A77795C2C49412714
ppp multilink
ppp multilink interleave
ppp multilink fragment delay 10
crypto map ***************
max-reserved-bandwidth 90
service-policy output QOS
- Rick one more thing we have around 190 remote sites  , and only this site shows this thing interesting !!
- If any issue with V.35 cable , will this error occur ???
Thanks & Regards,
Ram
