could somebody please explain what does
router#sh policy-map int GigabitEthernet0/0.15 out
Service-policy output: policy1
Class-map: Class-map1 (match-any)
36699 packets, 5431222 bytes
30 second offered rate 5000 bps, drop rate 0 bps
Match: access-group name ACL1
336 packets, 22512 bytes
30 second rate 0 bps
Match: access-group name ACL2
36363 packets, 5408710 bytes
30 second rate 5000 bps
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 36699/5438950
bandwidth remaining 37% (13 kbps)
Exp-weight-constant: 1 (1/2)
Mean queue depth: 0 packets
output mean?
The GigabitEthernet0/0.15 subinterface has bandwidth 4000 kbps configured (as well as GigabitEthernet0/0 interface).
There is one priority class configured with 512 kbps reserved.
I believe "bandwidth remaining 37% (13 kbps)" does not mean "bandwidth remaining 37% = 13 kbps"
So where does this 13 kbps come from?
The router is 2901 running c2900-universalk9-mz.SPA.151-2.T4.1 IOS.
Milan
