Dual DHCP WAN and IPSec
GeoPo
Hello All.
I have a 931 with two WAN links, both are DHCP, and I'm having issues bringing up a number of site-to-site IPSec Tunnels. It consists of 4 tunnels - one to each datacentre, over each WAN, as such;
WAN 1 > DC 1 (i.e 1.1.1.1)
WAN 1 > DC 2 (i.e 1.1.1.2)
WAN 2 > DC 1 (i.e 1.1.1.1)
WAN 2 > DC 2 (i.e 1.1.1.2)
Obviously I need routes in order to get these tunnels up, but if I allow the default route to be populated by the WAN DHCP leases, then two tunnels will succeed, and the other two will fail, as they will all route over the same WAN interface, whichever is picked as the primary default route.
If I use a static routes, I have a similar problem where the routes will match the destinations, and all traffic will be routed out a single WAN interface. For example;
ip route 1.1.1.1 255.255.255.255 interface g0
ip route 1.1.1.2 255.255.255.255 interface g0
ip route 1.1.1.1 255.255.255.255 interface g1
ip route 1.1.1.2 255.255.255.255 interface g1
I have played around with route-maps, but struggling to find compatible match and set atributes because the WAN interface addresses and gateways are all aquired via DHCP.
The tunnel interfaces are configured with a source address of the physical interface i.e tunnel source GigabitEthernet0
How would you recommend overcoming this issue? Any help greatly appreciated.
TLDR; How do I force IPSec Tunnels to the same destination route over alternate WAN links.
Thanks for reading.
You can use LO in both site
Then use vti as use LO as source and destiantion of tunnel.
This will make IPsec undependable of WAN
MHM
MHM
"This will make IPsec undependable of WAN"
For clarification, believe MHM is saying "This will make IPsec independent of WAN (addresses)".
Hello
can you elaborate a little on the topology
you have a single rtr with dual wan links
and you wish to create 4 tunnels to the same  two destinations addressing via both of these two transit wan links.
are these wan links internet facing or running over private enterprise network?
May I ask why 4 tunnels when you only have two destinations and a single rtr ?
Kind Regards
Paul
