02-05-2011 11:12 PM - edited 03-04-2019 11:20 AM
Good Day,
I'm trying to accomplish the following on my Cisco 1841 Router;
Dual ISP Multihoming - I want to be able to route traffic through ISP A and if ISP A goes down I want to re-route traffic through ISP B. I think I've got this part all sorted out... So its just the latter that I'm having problems with.
Web Browsing on ISP B - As an addition to the above... I want to be able to send all http(s) traffic to ISP B. I'm having some issues with this.. Can someone please assist.
Additionaly is it a best practice to run DNS on this Cisco 1841? and does this router have the resources to do so... I'm tempted to use the router as a DNS server because when switching between ISP's the DNS becomes an issue. ISP A does not allow the use of ISP B DNS and vice verse.
Please see config below.
Building configuration...
Current configuration : 3003 bytes
version 12.4
service password-encryption
boot-start-marker
boot-end-marker
logging buffered 50000
no aaa new-model
clock timezone Guyana -3
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool testFH_Guyana
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 190.124.220.2 190.124.220.3
archive
log config
hidekeys
track 10 ip route 69.147.114.224 255.255.255.255 reachability
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description ISP1 128Kbps Dedicated Circuit
ip address 190.108.199.64 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip nat enable
no ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description ISP2 512Kbps Dedicated Circuit
ip address 190.80.2.70 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip nat enable
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip nat enable
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 190.108.199.1 track 10
ip route 0.0.0.0 0.0.0.0 190.80.2.69 10
ip route 10.0.0.0 255.0.0.0 10.10.10.0
ip route 69.147.114.224 255.255.255.255 190.108.199.1
no ip http server
ip nat inside source route-map isp1 interface FastEthernet0/0 overload
ip nat inside source route-map isp2 interface FastEthernet0/1 overload
ip nat inside source static 10.10.10.6 190.80.2.197 route-map isp2static
ip nat inside source static 10.10.10.6 190.108.199.101 route-map isp1static
ip sla 10
icmp-echo 69.147.114.224
timeout 1000
frequency 5
ip sla schedule 10 life forever start-time now
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
no cdp run
route-map isp2static permit 10
match interface FastEthernet0/1
route-map isp1static permit 10
match interface FastEthernet0/0
route-map isp2 permit 10
match ip address 100
route-map isp1 permit 10
control-plane
banner motd ^C UnAuthorized Users STAY OUT ^C
line con 0
password 7 0968093E181C13175A555C7B
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 5 0
logging synchronous
login
transport input telnet
scheduler allocate 20000 1000
end
02-06-2011 01:40 AM
The following Optimised Edge Routing config example for two ISPs should help. It is using two IP SLA configs, one for each ISP.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
As for DNS you could point your PCs to one or more public DNS servers, eg Google.
http://code.google.com/speed/public-dns/
Please rate all posts that are helpful.
02-06-2011 08:14 AM
Thanks for the DNS info... but the config for load balancing does not allow me to choose a more-desirable connection over a less-desirable connection, which is what i required as well as to route all tcp 80 traffic through the alternate interface.
