Dual ISP Router w NAT/PAT and PBR
erosales
I am trying to figure out how to configure a router to perform NAT/PAT and PBR. We will be using AT&T for web and print servers and will use TPAC for all other traffic. The router should still perform NAT/PAT in the event that one link goes down. The ASA will not do any NAT and will only filter traffic using ACLs.
The print services will need to be PATed, as they will only have 1 IP address:
26.1.1.1:9000  10.1.1.10:9000
26.1.1.1:9001  10.1.1.11:9000
26.1.1.1:9002  10.1.1.12:9000
26.1.1.1:9003  10.1.1.13:9000
Thanks in advance for all the help!
Francesco Molino
Those public IPs are your assigned IPs. Are you exchanging that subnet with your ISPs? I mean, those IPs are from AT&T and if this link is going down, does traffic to those IPs are forwarded back to your through TPAC ISP?
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
The IP is not shared with the ISP. This is the IP for a cloud based print service.
Ok you have those IPs but can't advertise them through the other ISP. Is my understanding good?
to access those print services are you using IP or DNS?
If you're using only IPs and no way from someone on internet to reach your network then you don't have solutions
however if your using dns, you can have some dns failover and nat on your router like you're doing today but adding the other ISP public IP
Francesco
