08-05-2015 09:36 AM - edited 03-05-2019 02:00 AM
I have setup HSRP, NAT and IPSLA in a config like this before but these new 2911 running 15.x IOS seem to have a few of their HSRP/NAT features removed in favor of the new redundancy commands. Is it still possible to do the below config without adding another interface to the routers for data/control to pass over? Any links or examples would be greatly appreciated.
08-05-2015 03:13 PM
Duplicate thread.
Go HERE.
08-05-2015 04:25 PM
I have removed the other duplicate thread.
08-06-2015 12:37 AM
Wayne,
It is possible to do it.
The things you'll need to change would be on both routers:
Int gig0/2
standby ## name WAYNES-WORLD
ip nat Stateful id 1
redundancy WAYNES-WORLD
mapping-id 1
protocol udp
ip nat inside source list LISTNAME pool POOLNAME mapping-id 1 overload ! overload if desired
we ran into the same sort of problem when cisco removed the old stateful-nat configuration. If I misunderstood, my apologies.
--tim
08-07-2015 06:46 AM
I can't issue the command without getting an error.
OutsideDmzEdge-1(config)#ip nat Stateful id 1
*Aug 7 13:45:19.495: %PARSER-3-BADSUBCMD: Unrecognized subcommand 10 in configure command 'ip nat Stateful id 1 '
my exact IOS is:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
