Bookmark
Subscribe
652
Due to WCCP fake TUNNEL Creation on router 2911
Sandeep Choudhary
Hi All,
We have 5 Tunnel interfaces( we created only 1 & 2) on the router, not sure how it got there but we are unable to delete them or configure them.
They seem to take the loopback ip as source and if I delete the loopback interface it chooses another IP.
Now we want to configure tunne 3 and tunnel 4 for the other provider at remote office but tunnel 3 and tunnel 4 is automatically created by the WCCP.
questions:
1. How can we remove these tunnel 3 and 4 and replace with our ip address.
2. I dont want these tunnels in any case, is there any procedure to remove these tunnels.
Output from sh ip int brief,
Tunnel0                    172.16.0.1      YES unset  up                    up
Tunnel1                    10.13.70.2      YES NVRAM  up                    up
Tunnel2                    10.13.170.2     YES NVRAM  up                    up
Tunnel3                    172.16.0.1      YES unset  up                    up
Tunnel4                    172.16.0.1      YES unset  up                    up
rsimoni
Hi Sandeep,
In IOS versions where WCCP is VRF aware, such as 15.0M and 15.1T, the use of GRE redirection will result in some new tunnel interfaces appearing. On the ASR platform these tunnel interfaces are also present from IOS XE release 2.5 onwards (although VRF support within WCCP on the ASR platform is not present until IOS XE release 3.1).
So what you see is perfectly normal and you cannot do anything to change this, unless you want to change the WCCP redirection mode, or disable WCCP completely.
Riccardo
