Dynagen / dynamips - Router Emulation Video Tutorials
Not applicable
I created a few video tutorials for dynamips router emulation software and its front-end (dynagen) for those that are interested.
http://www.blindhog.net/category/dynamips/
Enjoy!
7 Replies 7
bradlesliect
This software is awesome. 2 FAQ's though:
1. How would you upgrade the flash and memory in the simulator? This is required for some IOS's
2. If I wanted to put 2x IOS's on the flash how would the simulator let me do that?
Good one
Post a comment. Deserves a rating for the effort.
Narayan
I'm sorry ....but you lost me? :(
Did I post a good comment? Do get a rating?
If so ... THANKS!
Also how do you add more IO cards to the simulator.
e.g. E1, FE, NPE,etc
The software automatically installs adapters based on the interfaces needed (eg f0/0, s0/0).
Here is a list of options available that can be configured in the dynagen .net configuration files.
autostart = boolean(default=True)
model = option('2610', '2611', '2620', '2621', '2610XM', '2611XM', '2620XM', '2621XM', '2650XM', '2651XM', '2691', '3725', '3745', '3620', '3640', '3660', '7200', default='7200')
ghostios = boolean(default=False)
ghostsize = integer(min=1, default=None)
sparsemem = boolean(default=False)
idlemax = integer(min=1, default=None)
idlesleep = integer(min=1, default=None)
oldidle = boolean(default=False)
debug = integer(min=0, max=9, default=0)
[__many__]
port = integer(min=1, max=65535, default=None)
workingdir = string(default=None)
console = integer(min=1, max=65535, default=None)
udp = integer(min=1, max=65535, default=None)
[[__many__]]
model = option('2610', '2611', '2620', '2621', '2610XM', '2611XM', '2620XM', '2621XM', '2650XM', '2651XM', '2691', '3725', '3745', '3620', '3640', '3660', '7200', default=None)
aux = integer(min=1, max=65535, default=None)
image = string(default=None)
ram = integer(min=0, default=None)
nvram = integer(min=0, default=None)
cnfg = string(default=None)
confreg = string(default=None)
idlepc = string(default=None)
exec_area = string(default=None)
clock = integer(min=0, default=None)
npe = option('npe-100', 'npe-150', 'npe-175', 'npe-200', 'npe-225', 'npe-300', 'npe-400', 'npe-g1', 'npe-g2', default=None)
midplane = option('std', 'vxr', default=None)
disk0 = integer(min=0, default=None)
disk1 = integer(min=0, default=None)
mmap = boolean(default=None)
ghostios = boolean(default=None)
sparsemem = boolean(default=None)
autostart = boolean(default=None)
configuration = string(default=None)
oldidle = boolean(default=None)
rated for the good effort
Narayan
If you want "total" control over the way dynamips runs, you will have to run dynamips without the dynagen front-end. I don't really have any experience with it (too lazy)
http://www.ipflow.utc.fr/dynamips/dynamips-0.2.7-RC3.tar.gz
Download the source-code above. Then, take a look at the README file. It looks like it gives good instructions for running dynamips 'stand-alone'.
