Showing results forĀ
Search instead forĀ
Did you mean:Ā
DynDNS in Cisco 891W
Alex Alvarez
In the context of use dyndns via HTTP, the syntax is
HTTP
add http://user:pass@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
But the symbol ? is not write in the file of running config, by consecuense the update is 404 error return
Anyone that know solution or idea to this problem? please help!
Greetings
James Neilson
You need to press Ctrl-V before the ?
Further details can be found here http://www.petri.co.il/csc_configuring_dynamic_dns_in_cisco_ios.htm#
James Neilson
Thank you, works fine !!!
