E1 configuration help needed...
bschmi
Community Member
I am trying to configure a channelized E1/PRI port on a Cisco 2851, connecting to a E1 (1984kb). Can anyone provide an example or a reference on the configuration? Thanks in advance!
paolo bevilacqua
It is ISDN PRI for data ?
If so search "configuring DDR". Else clarify what is it.
Sorry....it's for Data. The site has an E1 MPLS circuit. This router will be the redundant E1/Data IPsec tunnel backup route. I have the local ISP static addressing info with gateway
Then just configure card type (if vwic2). Under controller create a channel-group with the correct timeslot. A serial interface will appear, configure it and the rest as normal.
