E1 Interface taking errors
hakim.k82
Community Member
Hi Experts,
Currently our E1 interface is taking errors and we have checked a few times that the transmission is working fine (a few BERT test). We also have verified that the port on both ends are working fine by performing hard loopback test.
I've noticed that the ISP router show interface is showing subrate: 64Kb/s while the customer router show interface is showing SCC: 0. May I know if this could be reason why we keep on seeing error on the interface?
ISP show interface
ISP#sh int Se1/2/7:0
Serial1/2/7:0 is up, line protocol is up
  Hardware is SPA-8XCHT1/E1
  Description: "XX"
  Internet address is XX.XX.XX.XX/28
MTU 1500 bytes, BW 1984 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP, CDPCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:49:35
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     2825 packets input, 276569 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     50 input errors, 6 CRC, 10 frame, 0 overrun, 0 ignored, 34 abort
     1884 packets output, 99185 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions no alarm present
  Timeslot(s) Used:1-31, subrate: 64Kb/s, transmit delay is 0 flags
Customer show interface
customer#sh int Se0/0/0:0
Serial0/0/0:0 is up, line protocol is up
  Hardware is GT96K Serial
  Description: "XX"
  Open: IPCP, CDPCP, loopback not set
  Last clearing of "show interface" counters 11:49:35
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 0 bits/sec, 1 packets/sec
  30 second output rate 3000 bits/sec, 4 packets/sec
     26511 packets input, 1371262 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     478 input errors, 478 CRC, 78 frame, 9 overrun, 0 ignored, 194 abort
     40537 packets output, 3780034 bytes, 0 underruns
     4 unknown protocol drops
  Timeslot(s) Used:1-31, SCC: 0, Transmitter delay is 0 flags
paolo bevilacqua
Check "show controllers E1".
I have checked on the show controllers E1 and there's 'No alarms detected'.
ISP#sh controllers e1 1/2/7
E1 1/2/7 is up.
  Applique type is SPA-8XCHT1/E1
  No alarms detected.
  alarm-trigger is not set
  Framing is crc4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (162 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
     0 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     1 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
  Data in Interval 7:
  Data in Interval 8:
  Data in Interval 9:
     0 Line Code Violations, 1 Path Code Violations
     1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 10:
  Data in Interval 11:
  Data in Interval 12:
     2 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
  Data in Interval 13:
  Data in Interval 14:
  Data in Interval 15:
  Data in Interval 16:
  Data in Interval 17:
  Data in Interval 18:
     1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 1 Unavail Secs
  Data in Interval 19:
  Data in Interval 20:
  Data in Interval 21:
  Data in Interval 22:
  Data in Interval 23:
  Data in Interval 24:
  Data in Interval 25:
  Data in Interval 26:
  Data in Interval 27:
  Data in Interval 28:
  Data in Interval 29:
  Data in Interval 30:
  Data in Interval 31:
  Data in Interval 32:
  Data in Interval 33:
  Data in Interval 34:
  Data in Interval 35:
  Data in Interval 36:
  Data in Interval 37:
  Data in Interval 38:
  Data in Interval 39:
  Data in Interval 40:
  Data in Interval 41:
  Data in Interval 42:
  Data in Interval 43:
  Data in Interval 44:
  Data in Interval 45:
  Data in Interval 46:
  Data in Interval 47:
  Data in Interval 48:
  Data in Interval 49:
  Data in Interval 50:
  Data in Interval 51:
  Data in Interval 52:
  Data in Interval 53:
  Data in Interval 54:
  Data in Interval 55:
  Data in Interval 56:
  Data in Interval 57:
  Data in Interval 58:
  Data in Interval 59:
  Data in Interval 60:
  Data in Interval 61:
  Data in Interval 62:
  Data in Interval 63:
  Data in Interval 64:
  Data in Interval 65:
  Data in Interval 66:
  Data in Interval 67:
  Data in Interval 68:
  Data in Interval 69:
  Data in Interval 70:
  Data in Interval 71:
  Data in Interval 72:
  Data in Interval 73:
  Data in Interval 74:
  Data in Interval 75:
  Data in Interval 76:
  Data in Interval 77:
  Data in Interval 78:
  Data in Interval 79:
  Data in Interval 80:
  Data in Interval 81:
  Data in Interval 82:
  Data in Interval 83:
  Data in Interval 84:
  Data in Interval 85:
  Data in Interval 86:
  Data in Interval 87:
  Data in Interval 88:
  Data in Interval 89:
  Data in Interval 90:
  Data in Interval 91:
  Data in Interval 92:
  Data in Interval 93:
  Data in Interval 94:
  Data in Interval 95:
  Data in Interval 96:
  Total Data (last 24 hours)
     0 Line Code Violations, 12 Path Code Violations,
     0 Slip Secs, 8 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     18 Errored Secs, 0 Bursty Err Secs, 8 Severely Err Secs, 1 Unavail Secs
Circuit is not OK
Also possible that errors are introduce on the other side of the circuit.
