eBGP configuration under sub-interface
Abayomi Smith
Level 3
Level 3
Hello folks,
Once again I have come with a question I would be happy if anyone can help out with.
I have been tasked to configure eBGP with a PE router. According to the provider they have asked that a sub-interface be configured under the physical interface connecting to the PE equipment with both routers in different AS's.
The set up for illustartion purposes is as below.
CE_1(AS6111)------------PE_E(AS1261)-------------PE_BB(AS200)--------PE(AS921)--------CE_2(AS5432)
I have copied an excerpt of the configuration given with details for the CE_1 router below.
interface fa0/0/1
descriptionMPLS connection to PE_E
bandwidth 2000
ip mtu 1500
load-interval 30
duplex auto
speed auto
no  ip redirected broadcast
ip route-cache cef
Int fa0/0/1.83
description ***MGT connection to PE_E***
bandwidth 2000
ip address 172.168.23.2 255.255.255.252
encapsultaion dot1Q 83
no cdp enable
router bgp 6111
no synchronization
bgp log-neighbor-changes
bgp deterministic-med
redistribute connected route-map internal
neighbor 172.168.23.1 remote-as 1261
neighbor 172.168.23.1 send-community
neighbor 172.168.23.1 ebgp-multihop 2
neighbor 172.168.23.1 update-source fa0/0/1.83
neighbor 172.168.23.1 soft-reconfiguration inbound
neighbor 172.168.23.1 description VPNV4 to PE_E
neighbor 172.168.23.1 route-map vpn_in in
neighbor 172.168.23.1 route-map vpn_out out
no auto-summary
ip route 172.168.23.1 255.255.255.252 int gi1/0/1.83 (next hop connected interface)
ip bgp-community new-format
ip as-path access-list 10 permit _200_
ip as-path access-list 10 permit _400_
ip as-path access-list 10 permit _600_
ip as-path access-list 10 permit _1261_
ip access-list extended management_traffic
permit ip any 192.168.76.0 0.0.0.255
permit ip any 192.168.78.0 0.0.3.255
permit ip any 192.168.88.0 0.0.0.255
permit ip any 192.168.98.0 0.0.3.255
permit ip any 213.117.29 0.0.0.0.255
route-map vpn_out deny 5
match as-path 10
route-map vpn-out permit 10
set community 1511:3000 1511:3001 1511:3005 1511:5009 additive
route-map vpn_in deny 5
match community 94
ip community-list 94 permit 1511:810
route-map customer_internal permit 10
match ip address internal
However  this does not work, no bgp session established, cant even ping PE_E (not suprised with the dodgy ip route statement, not even sure if its a direct conenction rather than ebgp as PE router interface and CE router interface given are in the same subnet and they havent given any ip for loopback on the PE router.)
All documentation I have consulted, I have seen the loopback address used rather than the physical interface as the update source.
I have raised the issue with them and they are still looking at it however, I would appreciate if anyone can look at this config and raise possible pointers as to what is wrong apart from the obvious.
Thanks in advance,
Yomi
Collin Clark
Does the ARP table have a valid MAC for 172.168.23.1?
Thanks Colin.
I have not checked but will check first thing tomorrow as I just left the client site. show ip bgp sum shows 172.168.23.1 as the neighbor  but no msg rcvd or sent and up/down never.
I did a bit of troubleshooting and debug ip bpg shows open failed: connection timed out; remote host not responding, open active delayed 19621ms (35000ms max, 60% jitter)
I will check the ARP table for the MAC address entry for PE router
milan.kulik
Level 11
Level 11
IMHO, you don't need neither
nor
in your case.
I also see a discrepancy having gi1/0/1.83 in the route command while  fa0/0/1.83 connected to the PE?
Also neighbor 172.168.23.1 ebgp-multihop 2
should not be necessary if using interface IP addresses.
As you are saying you are not able to Ping the PE IP address which is in the same directly connected subnet, you need to fix this first.
I guess the encapsulation VLAN ID might be incorrect?
HTH,
Milan
Thanks Milan,
Yes I am not able to ping the PE router connecting interface. To be honest the SP isnt really helping matters, I want to believe they are directly connected based on the fact that they are in the same subnet. I suspect the problem is on the SP end as the transmit port on the DSU of the SP is permananetly amber while receive is blinking green. This I have also raised with them and they are looking into it.
