eBGP redist static command?
shaun.white
Hello
I have two routers connected back to back...im running eBGP between them...i want to do redist static (to enter the serial interface networks into BGP without using the network statement, however when i do this i do not see the routes...any ideas? TIA
interface Serial1/0
description Connection to BGP WAN rtr
ip address 172.26.10.2 255.255.255.252
no ip directed-broadcast
no ip mroute-cache
no fair-queue
clockrate 56000
interface Serial1/1
no ip address
shutdown
interface Serial1/2
description Connection to Remote WAN BGP RTR
ip address 172.26.10.10 255.255.255.252
interface Serial1/3
no ip address
shutdown
router bgp 65511
no synchronization
redistribute connected
neighbor 172.26.10.1 remote-as 65512
neighbor 172.26.10.9 remote-as 65510
the neighbor routers are configured the same (for EBGP just with the different serial IPs)
wochanda
Level 4
Level 4
If you do a 'show ip bgp' on this router, do you see the routes in your own bgp table?
If so, does a 'show ip bgp neighbor 172.26.10.1 advertised-routes' show the routes?
What does a 'show ip bgp' on the remote router look like? Is it completely blank?
If you use 'network' statements, do the neighbors get the routes then?
Thanks for the reply...but it was a long day and i was missing it...i figured it out...BGP was auto summarizing...therefore sending out the aggregated routes
jabranzahid
If you want to redistribute connected networks into bgp, you need to use 'redistribute connected' command.
Hope this helps
Jabran
