EEM script error
we have configured EEM script on the router to shut the BGP neighbour. but its not working.
ip sla 30
icmp-echo 10.1.32.106 source-ip 10.3.165.198
threshold 260
timeout 500
frequency 3
ip sla schedule 30 life forever start-time now
ip sla enable reaction-alerts
track 30 ip sla 30 reachability
delay down 5 up 180
ip route 10.1.32.106 255.255.255.255 10.3.165.197
event manager applet SWDC_REACHABILITY_DOWN
event syslog pattern "30 ip sla 30 reachability Up -> Down"
action 1.0 cli command "enable"
action 1.1 cli command "configure term"
action 1.2 cli command "router bgp 64760"
action 1.3 cli command "neighbor 10.3.165.197 shutdown"
action 1.4 cli command "end"
event manager applet SWDC_REACHABILITY_UP
event syslog pattern "30 ip sla 30 reachability Down -> Up"
action 1.3 cli command "no neighbor 10.3.165.197 shutdown"
kindly suggest please to fix..
9 Replies 9
Hello
event track 30 state down
event track 30 state up
res
Paul
Kind Regards
Paul
can you tell me what mistakes i made in my configuration and which commands needs to be include?
can you explain?
Hello
As far as i can see it looks okay apart from the applet wasn't monitoring the tracking but the ip sla
Just try the below changes and test again
res
Paul
Kind Regards
Paul
on a side note, I think this should work as is, you might want to change the delay values and add the reaction threshold:
delay down 5 up 5
ip sla reaction-configuration 30 react timeout threshold-type immediate
Hello
I guest if you going to use ip sla then tracking isn't required as such you may need to change the applet anyway
event manager applet test
 event syslog pattern ".*OPER_TIMEOUT: condition occurred, entry number = 30"
Test and see, it may may not work I have not tested it myself
res
Paul
Kind Regards
Paul
we have tried all options but not luck
Hello
Can you ping 10.1.32.106  sourced from 10.3.165.198 ?
sh ip sla  statistics
sh track
res
Paul
Kind Regards
Paul
No luck means the script isn't running at all ? Post the full config of your router...
Issue resolved after enabling no authorization coomand for eem script
Thanks for all..
