BGP route advertised but unable to ping
Ashwani Pande
Hi Everyone,
Can someone correct me on a BGP issue. It's not a real time environment. There are two customer's running BGP and in different AS. One location is using RIP and other is EIGRP. Peering between two routers using loopback IP addresses and static route is defined for them. BGP is showing "EST". When I am advertising one network which I have in my routing table to customer (B) using network and subnet command I can see that network on the otherside available but when I tried to ping from there I am unable to ping it? Why?
I know nexthop should be reachable but here BGP is running only on two routers and I am trying to ping from the router where I can see that advertised route. Any suggestions? No auto-summary is configured.
2 Accepted Solutions
you need to do at a minimum the below redistribution into RIP:
router rip
version 2
network 5.0.0.0
network 20.0.0.0
redistribute connected
no auto-summary
Basically the next-hop (20.1.1.1) towards the final destination was not present in the RIB on Router A.
So by redistributing connected on Router B advertised the next-hop interface in RIP.
HTH.
Terence
10 Replies 10
post the configs of both routers...
RouterB#
interface Loopback0
ip address 5.5.5.5 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 20.1.1.2 255.255.255.252
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 122.1.1.1 255.255.255.252
clock rate 2000000
router rip
version 2
network 5.0.0.0
network 20.0.0.0
no auto-summary
router bgp 200
no synchronization
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.252
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 ebgp-multihop 2
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
ip forward-protocol nd
ip route 1.1.1.1 255.255.255.255 122.1.1.2
RouterA#
interface Loopback0
ip address 1.1.1.1 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 192.168.1.1 255.255.255.252
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 122.1.1.2 255.255.255.252
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 192.168.1.0 0.0.0.3
no auto-summary
router bgp 100
no synchronization
neighbor 5.5.5.5 remote-as 200
neighbor 5.5.5.5 ebgp-multihop 2
neighbor 5.5.5.5 update-source Loopback0
no auto-summary
ip route 5.5.5.5 255.255.255.255 122.1.1.1
RouterA#
#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
2.0.0.0/32 is subnetted, 1 subnets
D 2.2.2.2 [90/2297856] via 192.168.1.2, 00:46:21, Serial0/0
168.1.0.0/30 is subnetted, 1 subnets
D 168.1.1.0 [90/3193856] via 192.168.1.2, 00:46:20, Serial0/0
3.0.0.0/32 is subnetted, 1 subnets
D 3.3.3.3 [90/2809856] via 192.168.1.2, 00:46:20, Serial0/0
4.0.0.0/32 is subnetted, 1 subnets
D 4.4.4.4 [90/3321856] via 192.168.1.2, 00:46:20, Serial0/0
5.0.0.0/32 is subnetted, 1 subnets
S 5.5.5.5 [1/0] via 122.1.1.1
172.32.0.0/30 is subnetted, 1 subnets
D 172.32.1.0 [90/2681856] via 192.168.1.2, 00:46:23, Serial0/0
10.0.0.0/30 is subnetted, 1 subnets
B 10.1.1.0 [20/1] via 5.5.5.5, 00:45:26
122.0.0.0/30 is subnetted, 1 subnets
C 122.1.1.0 is directly connected, Serial0/1
192.168.1.0/30 is subnetted, 1 subnets
C 192.168.1.0 is directly connected, Serial0/0
RouterB advertising 10.0.0.0/30 to Router A and we can see above it is in the routing table.
where is 10.1.10/30 configured ? It needs to be visible with 'show ip route' on Router B.
router bgp 200
no synchronization
no auto-summary
The below is a working sample config of network 10.10.10.10 being reachable from R1. For that to happen, it actually needs to exist on R2
R1
interface Loopback0
interface GigabitEthernet0/0
ip address 192.168.12.1 255.255.255.252
duplex auto
speed auto
media-type rj45
router bgp 1
bgp router-id 1.1.1.1
neighbor 2.2.2.2 remote-as 2
neighbor 2.2.2.2 ebgp-multihop 255
neighbor 2.2.2.2 update-source Loopback0
ip route 2.2.2.2 255.255.255.255 192.168.12.2
R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Loopback1
ip address 10.10.10.10 255.255.255.255
ip address 192.168.12.2 255.255.255.252
duplex auto
speed auto
media-type rj45
router rip
version 2
network 10.0.0.0
router bgp 2
bgp router-id 2.2.2.2
network 10.10.10.10 mask 255.255.255.255
neighbor 1.1.1.1 ebgp-multihop 255
ip route 1.1.1.1 255.255.255.255 192.168.12.1
The only difference I can see here is in your topology network 10.10.10.10 is locally configured as well however in my case it is learned via IGP.  I believe both  conditions should be okay to advertise route until you can ping it and route exist.
Okay when I created another loopback 100.100.100.100/32 and first advertised it through RIP and then advertised to peer BGP I am able to ping it from there.
Now my question is why I am unable to ping the other advertised route? the only difference is 100.100.100.100/32 I have created it locally and 10.1.1.0/30 I have got through IGP.
thanks for your help.
yes it is visible in the routing table and I am able to ping it from RouterB. Below is the output of sh ip route.
sh ip route
S 1.1.1.1 [1/0] via 122.1.1.2
20.0.0.0/30 is subnetted, 1 subnets
C 20.1.1.0 is directly connected, Serial0/0
C 5.5.5.5 is directly connected, Loopback0
7.0.0.0/32 is subnetted, 1 subnets
R 7.7.7.7 [120/2] via 20.1.1.1, 00:00:08, Serial0/0
R 10.1.1.0 [120/1] via 20.1.1.1, 00:00:08, Serial0/0
It is learned via IGP(RIP.)
ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/16 ms
router rip
version 2
network 5.0.0.0
network 20.0.0.0
no auto-summary
Okay yes. that worked and now able that ping  that 10/30 network as well however I would like to know what is the logic behind this as what I have heard that you can advertise any network that you have in your routing table and should be reachable via any IGP and these two conditions i have met here.
HTH.
Terence
