EHWIC-4G-LTE-G Config, 1900 Series Router, EE Connection
pr-graves-2011
Thank you in advance for any support!
I'm configuring a 1900 series router with a 4g module installed and a working SIM, but I am not receiving an IP from EE. My cellular interface is up and the cellular module has an APN configured. All config seen below. Could someone please have a read through and check for what I am missing. The statuses on the cell interface are all up but still not receiving an IP...
LTE Profile....
Router#cellular 0/0/0 lte profile create 1 everywhere pap eesecure secure
Cellular Interface...
Router>sh int cel0/0/0
Cellular0/0/0 is up (spoofing), line protocol is up (spoofing)
Hardware is 4G WWAN EHWIC - Global Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS
Internet address will be assigned dynamically by the network
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 100000 usec,
Encapsulation SLIP, loopback not set
Keepalive not supported
Last input 00:15:11, output never, output hang never
Queueing strategy: fifo
Output queue: 0/10 (size/max)
4 packets input, 112 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
FULL Config.....
Current configuration : 1933 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
chat-script lte"" "AT!CALL" TIMEOUT 60 "OK"
license udi pid CISCO1921/K9 sn FCZ1735C3ML
controller Cellular 0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
switchport access vlan 20
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface Cellular0/0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string LTE
dialer-group 1
interface Vlan1
no ip address
interface Vlan20
ip address 10.0.2.1 255.255.255.0
ip nat inside
router eigrp 1
network 0.0.0.0
network 10.0.2.0 0.0.0.255
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT-VLAN20 interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip access-list standard NAT-VLAN20
permit 10.0.2.0 0.0.0.255
access-list 1 permit any
dialer-list 1 protocol ip list 1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
script dialer LTE
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Helllo @pr-graves-2011 ,
>> Jun 28 10:22:34.799: CHAT0/0/0: Dialing using Modem script: LTE"" & System script: none
please config under line0/0/0
line 0/0/0
no script dialer LTE
script dialer lte
LTE is a null string for the router
Hope to help
Giuseppe
7 Replies 7
Giuseppe Larosa
Hello @pr-graves-2011 ,
your chat script is named lte and not LTE
in interface config you have:
ip nat outside
encapsulation slip
dialer in-band
>>>>>>>> dialer string LTE
change it to dialer string lte
Hope to help
Giuseppe
I will give this a go..... 1st time working out configuring 4G connections. Thank you so much for replying and I'll keep you posted how it goes!
pr-graves-2011
I had the following line config missing....
line 0/0/0
exec-timeout 0 0
script dialer LTE
modem InOut
no exec
Currently seeing this with dialer debugging....
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Jun 28 10:22:34.799: Ce0/0/0 DDR: place call
*Jun 28 10:22:34.799: Ce0/0/0 DDR: Dialing cause ip (s=10.0.2.1, d=8.8.8.8)
*Jun 28 10:22:34.799: Ce0/0/0 DDR: Attempting to dial LTE
*Jun 28 10:22:34.799: CHAT0/0/0: Attempting async line dialer script
*Jun 28 10:22:34.799: CHAT0/0/0: Dialing using Modem script: LTE"" & System script: none
*Jun 28 10:22:34.799: CHAT0/0/0: process started
*Jun 28 10:22:34.799: CHAT0/0/0: Asserting DTR
*Jun 28 10:22:34.799: CHAT0/0/0: Chat script LTE"" started...
*Jun 28 10:22:39.799: CHAT0/0/0: Chat script LTE"" finished, status = Connection timed out; remote host not responding
*Jun 28 10:22:39.799: Ce0/0/0 DDR: disconnecting call..
Success rate is 0 percent (0/5)
Router#
Current cell interface status...
MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
DCD=down DSR=down DTR=up RTS=up CTS=up
....so my DCD and DSR are now down. Not sure what is going on here. Any other pointers please?
Many thanks!
line 0/0/0
script dialer lte
Hope to help
Giuseppe
Thanks again Guiseppe!
The dialler just seems to be timing out now....
*Jun 28 13:32:03.171: Ce0/0/0 DDR: place call
*Jun 28 13:32:03.171: Ce0/0/0 DDR: Dialing cause ip (s=10.0.2.5, d=8.8.8.8)
*Jun 28 13:32:03.171: Ce0/0/0 DDR: Attempting to dial lte
*Jun 28 13:32:03.171: CHAT0/0/0: Attempting async line dialer script
*Jun 28 13:32:03.171: CHAT0/0/0: Dialing using Modem script: lte"" & System script: none
*Jun 28 13:32:03.171: CHAT0/0/0: process started
*Jun 28 13:32:03.171: CHAT0/0/0: Asserting DTR
*Jun 28 13:32:03.171: CHAT0/0/0: Chat script lte"" started
*Jun 28 13:32:08.171: CHAT0/0/0: Chat script lte"" finished, status = Connection timed out; remote host not responding
show cel0/0/0 ....
DCD=down DSR=up DTR=down RTS=up CTS=up
....I think this is now down to bad signalling, right? I haven't made any changes to the profile since the start of this and everything with the SIM etc seemed okay at the start.
Radio Information
Radio power mode = ON
Current RSSI = -61 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = LTE
Network Information
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 30
Packet switch domain(PS) state = Attached
Registration(EMM) state = Registered
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Unknown
Thanks again!
yes now you have the correct script invoked but the signal level may be too low
Hope to help
Giuseppe
pr-graves-2011
I moved the router and now RSSI = -84, so no better here unfortunately.
The chat-script is finishing right after starting as seen here...
*Jun 28 16:35:54.087: CHAT0/0/0: Chat script lte"" started
*Jun 28 16:35:59.087: CHAT0/0/0: Chat script lte"" finished, status = Connection timed out; remote host not responding
Many thanks for your replies!
