Eigrp and variance values
robert
Level 2
Level 2
I´m just starting to learn eigrp and have a question with the variance values when load balancing.
I have 2 routers, R1 and R2, and they have communication to each other via 2 vlans.
R1:
interface Loopback1
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
description WAN
ip address 33.33.33.1 255.255.255.0
ip ospf authentication message-digest
ip ospf authentication-key password
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.1.1.101 255.255.255.0
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 10.2.1.101 255.255.255.0
router eigrp 5050
network 33.33.33.0 0.0.0.255
network 10.1.1.0 0.0.0.255
network 10.2.1.0 0.0.0.255
no auto-summary
R2:
interface Loopback1
ip address 1.1.1.1 255.255.255.255
ip address 17.17.17.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip address 10.1.1.100 255.255.255.0
ip address 10.2.1.100 255.255.255.0
router eigrp 5050
variance 2
network 17.17.17.0
no auto-summary
If I set variance to 2 on R1 it will update it´s routing table to 17.17.17.0 with 2 entries (routing through 10.1.1.0 and 10.2.1.0) so I´ll load balance traffic going to this destination. But will it work it variance is set to default=1 on R2 ?
Then only one end is load balancing. Is this valid?
Robert
2 Accepted Solutions
cadet alain
R1 should have 2 routes to 17.17.17.0 without the variance command as these 2 paths should have same FD so they should be considered as 2 successors.What variance does is install unequal cost routes in the RIB provided
1st the feasibility condition must be met that is the second route must be considered as feasible successor( RD < FD of successor)
2nd the FD of FS * Variance <= FD of successor
Then the switching process will take care of the load sharing but it is only one way of course.
Regards.
Alain
Cadet Alain is correct- even without the variance command you should have two paths back to 17.17.17.0/24 in your route table.
But let say you have unequal costs - then you will have only one path back to 17.17.17.0/24 as the composite metric in eigrp will be different and eigrp it will take the lowest value.
You can view this metric ( lets say from R1(  by “ sh ip eigrp topology 17.17.17.0/24” – this will show you all the metrics for all links to this network
EG (143360/128256) – these metrics are linked to the feasible successor Cadat Alain has mentioned.
The 1st  metric calculated from R1 to destination
The 2nd metric is advertised by the neighbour.(R2)
For unequal cost load balancing - you can use the variance command -
Divide the highest and lowest composite metric for your network (in this case 17.17.17.0/24) - lets say 156160/143360 =1.089
round this up to the nearest whole value = 2
Both RTR
router eigrp 5050
variance 2
You should then see both paths populated in the route table with the two different composite metrics.
Res
Paul
Kind Regards
Paul
Abzal
Level 11
Level 11
What is connected on R2 on 10.1.1.100? Post here your network diagram. It's still not clear .
Best regards,
Abzal
Best regards,
Abzal
cadet alain
Regards.
Alain
Both RTR
router eigrp 5050
variance 2
Res
Paul
Kind Regards
Paul
Super, thanks to all.
Your are correct, both routes exist in the routing table as they have equel cost. So what I learned:
a. equal cost routes is automatic added to routing table
b. variance is only nessesary when I have unequal cost for my routes
robert
