EIGRP Bandwidth Configuration
aravind r v
Dear Team,
We are trying to establish two DMVPN tunnel to one Hub router. We need to publish same subnet from both routers and we need to achieve redundancy with that. We are using EIGRP as routing protocol between the tunnel.
I believe we can achieve EIGRP routing redundancy with changing bandwidth and delay values in one tunnel interface. We tried to do that but in Hub side Router still both router Bandwidth/Delay didn't changed.
please find the attached EIGRP config in both spoke routers.
PRIMARY ROUTER
interface Tunnel1
 description ++++ Primary DMVPN Cloud 1 ++++
 bandwidth 10000
 ip address 192.168.250.16 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1400
 no ip next-hop-self eigrp 100
 no ip split-horizon eigrp 100
 ip nhrp authentication mykey
 ip nhrp map multicast 1.1.1.1
 ip nhrp map 192.168.250.1 1.1.1.1
 ip nhrp network-id 11
 ip nhrp holdtime 180
 ip nhrp nhs 192.168.250.1
 ip tcp adjust-mss 1360
 tunnel source GigabitEthernet0/1
 tunnel mode gre multipoint
 tunnel key 11
 tunnel protection ipsec profile dmvpn
end
router eigrp 100
 network 172.16.111.80 0.0.0.15
 network 192.168.250.0
 redistribute static
 passive-interface default
 no passive-interface Tunnel1
SECONDARY ROUTER
interface Tunnel1
 description ++++ Primary DMVPN Cloud 2 ++++
 bandwidth 20000
 ip address 192.168.250.17 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1400
 delay 5000
 tunnel key 11
end
router eigrp 100
 redistribute static
Kindly Advise
Thanks & Regards,
ARV
Luis Jimenez
you can try with offset-list, please read this
Use an offset-list on R4 to Modify the Composite Metric at R2
The Composite Metric on R2 can be modified using an offset-list on router R4. An offset-list value of 20 on R4 increases the Composite Metric for the path R2-R4 by 20 on R2. Therefore, the path R2-R4 becomes a backup path to R2-R3. An offset-list is the preferred method if:
  • You only want to influence a particular path being advertised.
  • Additional routers are connected to the 10.1.3.0/24 subnet and you do not want to influence paths originated by the routers.
  1. Configure an offset-list on R4 that increases (by 20) the delay for any route starting with 10.1.3.x.
    R4# configure terminal
    Enter configuration commands, one per line.  End with CNTL/Z.
    R4(config)# access-list 99 permit 10.1.3.0 0.0.0.255
    R4(config)# router eigrp 1
    R4(config-router)# offset-list 99 out 20 e0/0
    R4(config-router)# end
    R4#
  2. You can in this output that the offset-list does not change anything in the EIGRP topology table on R4.
    The metric changes only when the route is advertised.
    R4# show ip eigrp topology 10.1.3.0 255.255.255.0
    IP-EIGRP (AS 1): topology entry for 10.1.3.0/24
      State is Passive, Query origin flag is 1, 1 Successor(s), FD is 281600
      Routing Descriptor Blocks:
      0.0.0.0 (Ethernet0/1), from Connected, Send flag is 0x0
          Composite metric is (281600/0), Route is Internal
          Vector metric:
            Minimum bandwidth is 10000 Kbit
            Total delay is 1000 microseconds
            Reliability is 255/255
            Load is 1/255
            Minimum MTU is 1500
            Hop count is 0
      10.1.2.3 (Ethernet0/0), from 10.1.2.3, Send flag is 0x0
          Composite metric is (307200/281600), Route is Internal
          Vector metric:
            Total delay is 2000 microseconds
            Load is 1/255
            Minimum MTU is 1500
            Hop count is 1
  3. On R2, confirm that the route through R3 (10.1.2.3) is once again the only best path.
    R2# show ip route
    Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
           D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
           N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
           E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
           i - ISIS, L1 - ISIS level-1, L2 - ISIS level-2, * - candidate default
           U - per-user static route, o - ODR
    Gateway of last resort is not set
         10.0.0.0/24 is subnetted, 3 subnets
    D       10.1.3.0 [90/307200] via 10.1.2.3, 00:00:20, Ethernet0
    C       10.1.2.0 is directly connected, Ethernet0
    C       10.1.1.0 is directly connected, Serial0.101
    The EIGRP topology table reflects the increase in delay from R4 (10.1.2.4).
    R4 feasible distance (281600) + R4 offset-list (20) = R4 reported distance (281620).
    Note: A cosmetic defect in Cisco IOS Software Release 12.0(7) prevents the increased delay from being accurately reflected in the Total Delay section of the output shown here.
    DDTSDescription
    CSCdp36097 (registeredcustomers only)EIGRP: offset-list adds incorrect delay value
    R2# show ip eigrp topology 10.1.3.0 255.255.255.0
      State is Passive, Query origin flag is 1, 1 Successor(s), FD is 307200
      10.1.2.3 (Ethernet0), from 10.1.2.3, Send flag is 0x0
          Vector metric:
            Load is 1/255
            Minimum MTU is 1500
            Hop count is 1
      10.1.2.4 (Ethernet0), from 10.1.2.4, Send flag is 0x0
          Composite metric is (307220/281620), Route is Internal
          Vector metric:
            Load is 1/255
            Minimum MTU is 1500
            Hop count is 1
Luis Thanks for the reply.
So you mean to say changing the bandwidth and delay in tunnel interface will not change the bandwidth ad delay in Hubside???
ARV
it´s no that simple remenber that If you change the bandwidth this could be worse because the bandwidth is used for QOS and other decisions on the routing process
