EIGRP load balancing over T1 Point to Point Circuits
jackremboldt
3 questions. The third is the most important.
1. I have 2 circuits connected to the same 2811 router (pairs), how can I configure EIGRP to load balance the traffic?
2. I have 1 Circuit in each of 2 seperate 2811 Router (pairs) How can I configure these to balance the traffic?
3. I have 2 Circuits in each of 2 pairs of 2811 routers, how can I load balance accrossed all 4 circuits.
Thanks, Jack
lgijssel
Level 9
Level 9
This should be achieved easily by configuring all links with the same bandwidth. EIGRP will then automatically load-balance between identical circuits. I think that you can use eigrp variance to account for the difference caused by the local LAN hops:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009437d.shtml
even more info on eigrp load balancing:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
and
http://www.cisco.com/en/US/tech/tk365/tk207/tsd_technology_support_sub-protocol_home.html
Hope this helps you out.
Leo
