EIGRP Neighborship stays down
ali.mouslmani
We are facing a problem with eigrp neighborship between branches and HO in a DMVPN network.
The eigrp between several branch routers and HO router, is flapping all the time (most probably due to link issue).
However, at certain point the neighborship goes down and doesn't go up although the tunnel is up and there is reachability from both sides.
The neighborship doesn't go up unless we clear DMVPN or shut/no shut the tunnel interface.
During the problem, the traffic passes through Tunnel2(which is on a stable link) and the "show ip route" output doesn't show entries corresponding to Tunnel1(eigrp flapping)
HO Router 7200
#show log
Feb 8 08:12:20 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.17.254 (Tunnel1) is up: new adjacency
Feb 8 08:12:22 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.1 (Tunnel1) is up: new adjacency
Feb 8 08:12:45 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.2 (Tunnel1) is down: retry limit exceeded
Feb 8 08:12:49 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.2 (Tunnel1) is up: new adjacency
Feb 8 08:13:13 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.2 (Tunnel1) is down: stuck in INIT state
Feb 8 08:13:13 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.1 (Tunnel1) is down: stuck in INIT state
Feb 8 08:13:13 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.17.254 (Tunnel1) is down: stuck in INIT state
Feb 8 08:13:13 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.1 (Tunnel1) is up: new adjacency
Feb 8 08:13:14 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.17.254 (Tunnel1) is up: new adjacency
Feb 8 08:13:17 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.2 (Tunnel1) is up: new adjacency
Feb 8 08:14:24 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.1 (Tunnel1) is down: stuck in INIT state
Feb 8 08:14:24 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.16.2 (Tunnel1) is down: stuck in INIT state
Feb 8 08:14:24 Beirut: %DUAL-5-NBRCHANGE: EIGRP-IPv4 1: Neighbor 10.214.17.254 (Tunnel1) is down: stuck in INIT state
#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 13:06 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
BR1274R1 uptime is 11 weeks, 1 day, 4 hours, 33 minutes
System restarted at 08:11:14 Beirut Thu Nov 10 2016
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 471040K/53248K bytes of memory.
Processor board ID FCZ174170WX
3 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2911/K9 FCZ174170WX
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
14 Replies 14
Mark Malone
So you have several branches all having issues flapping  ,  is it the core link you see an issue on  are you seeing issues on the physical link that may be causing this , crcs , up.down etc
are you using standard eigrp timers or have you set them more aggressively  , can you post the dmvpn spoke and hub config with the eigrp config to see what way its setup
have you tried lowering the mtu on the tunnel make sure it matches both sides too and your tcp adjust is set, increase the timers as a test too , hello and holdown
 is this like this since it was installed or has it only stared happening recently ?
probably need a debug to see exactly why its flapping ...debug eigrp packet
Hello Mark,
Thanks for your reply.
However, this a DMVPN setup of couple hundred routers, and changing mtu, mss, hello and holdown timers cannot be done between a spoke and the hub unless done on all.
We will check eigrp packet debugs.
ah ok yes then don't change the timers if you have working links I thought the issue was all links were effected in the dmvpn setup
you could run an ip sla between the effected link and the hub see how much traffic its dropping traffic too as a test , the debug may provide something concrete though
Could you please check the routing table and verify if the tunnel destination is not being received through the tunnel.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
it is statically routed
Is this physical interface racking up errors constantly ?
Hello
How are you mapping multicast to the NHRP NHS , Dynamically or statically?
res
Paul
Kind Regards
Paul
Statically.
Could you please share the tunnel configuration? multicast dynamic on the hub?
interface Tunnel1
description Branch MW DMVPN
bandwidth 512
ip address 10.214.17.148 255.255.254.0
no ip redirects
ip mtu 1400
ip flow ingress
ip flow egress
ip nhrp authentication evx9ql*0
ip nhrp group MW_NHRP
ip nhrp map multicast 10.214.104.1
ip nhrp map 10.214.16.1 10.214.104.1
ip nhrp map 10.214.16.2 10.214.104.5
ip nhrp map multicast 10.214.104.5
ip nhrp map 10.214.17.254 10.214.111.245
ip nhrp map multicast 10.214.111.245
ip nhrp network-id 1
ip nhrp holdtime 450
ip nhrp nhs 10.214.16.1
ip nhrp nhs 10.214.17.254
ip nhrp nhs 10.214.16.2
load-interval 30
delay 30000
if-state nhrp
qos pre-classify
tunnel source GigabitEthernet0/2
tunnel mode gre multipoint
tunnel key 153072607
tunnel protection ipsec profile mw_prof
do you have 2 hubs? I see 2 multicast maps.
Yes. 2 hubs.
Hello
Can you do the following and the test again
NHC
Int tun 1
shut
no ip nhrp map 10.214.16.2 10.214.104.5
no ip nhrp map multicast 10.214.104.5
no ip nhrp map 10.214.17.254 10.214.111.245
no ip nhrp map multicast 10.214.111.245
no shut
NHS
clear  ip eigrp  neighbors x.x.x.x (NHC)  _ this will just reset that specific adjacency
res
Paul
Kind Regards
Paul
I will try this and get back to you.
