EIGRP network problem
kapish.mohole
I am having a problem with a normal EIGRP routing configuration.
Router A
router eigrp 100
redistribute static
network 10.1.0.0 0.0.255.255
network 10.250.1.1 0.0.0.0
network 10.250.1.8 0.0.0.7
network 10.250.1.16 0.0.0.7
network 10.250.2.8 0.0.0.7
network 192.168.1.0 0.0.0.127
no default-information in
auto-summary
ip classless
Router B
router eigrp 100
redistribute static
network 10.2.1.0 0.0.0.255
network 10.250.2.1 0.0.0.0
network 10.250.2.16 0.0.0.7
auto-summary
ip classless
The 10.250.x.x IPs are the device interconnect IPs of 8 bit, connection to other devices and LAN. The 192.168.1.x is the subnet for WAN (Actually LAN, a VPLS network) addressing.
The LAN/VPLS connection between 192.168.1.x network is up, I can see both router as EIGRP neighbors but they don't exchange any routes. There are no routes learned from EIGRP in the routing table.
If I assign 10.250.1.x IP to the same interfaces of both routers then I see neighbors and can see learned routes in the routing table. Everything works very well when 10.250.1.x IP is used on both ends but for same physical interface/link they don't learn any routes if 192.168.1.x IP is used. What could be the reason?
Kapish
Thanks for the additional information. Based on this I believe that your problem is that auto-summary is configured. Your network appears to have discontiguous subnets when the VLAN 980 is configured with the 192.168.1 addresses (some subnets on 10.0.0.0 on routerA separated from subnets of 10.0.0.0 on routerB by the 192.168.1 network). And discontiguous subnets are a problem when auto-summary is configured. When you configure VLAN 980 with network 10.250.1 then it is contiguous and the subnets are learned. If you configure no auto-summary on both routers then they should work ok with the 192.168.1 addresses.
Rick
Rick
8 Replies 8
Richard Burts
Is it possible that the interfaces are configured with secondary addresses?
If not please provide more information about the interfaces and how they are configured.
Rick
Rick
This is the IP addressing that is working right now, EIGRP is learning routes when 10.250.1.17 and 18 with 29 bit mask IP used for VLAN 980. 980 Vlan is the VPLS network. If I use 192.168.1.x/24 on both ends for 980 vlan EIGRP doesn't learn any routes, just shows neighbors.
Loop back and tunnel interfaces are for GRE as backup link, it works very well. the bandwidth on interface will determine the best path either GRE or VPLS, vlan 980 is of higher BW.
Router A
interface Tunnel0
bandwidth 10000
ip address 10.250.2.10 255.255.255.248
keepalive 1 2
tunnel source Loopback0
tunnel destination 10.250.2.1
interface Loopback0
ip address 10.250.1.1 255.255.255.255
interface GigabitEthernet0/1
switchport access vlan 980
interface Vlan980
bandwidth 100000
ip address 10.250.1.17 255.255.255.248
Router B
interface Tunnel0
bandwidth 10000
ip address 10.250.2.9 255.255.255.248
keepalive 1 2
tunnel destination 10.250.1.1
interface Loopback0
ip address 10.250.2.1 255.255.255.255
interface Vlan980
bandwidth 100000
ip address 10.250.1.18 255.255.255.248
dosent work (keeping other inferfaces' config same) -
Router A
interface Vlan980
bandwidth 100000
ip address 192.168.1.10 255.255.255.0
Router B
interface Vlan980
bandwidth 100000
ip address 192.168.1.11 255.255.255.0
Kapish
Rick
Rick
Hi, Thanks for the reply.
Thats what I was thinking of, auto-summery creating this problem. I will try it today.
It was the auto-summery causing this problem.
Kapish
Thanks for posting back to the forum and confirming that it was the auto-summary that was causing the problem. It helps the forum when a problem is described and a solution is suggested and it is confirmed that the solution did solve the problem.
Rick
Rick
Yes, That is true. I am giving you points for this :)
Kapish
Thank you. You have not only posted back to the forum to confirm the problem and its solution but now you have used the rating system to indicate that your problem was resolved. Using the rating system makes it obvious to people looking at a discussion thread that they will see responses which did resolve the problem and this is very helpful for the forum.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
