EIGRP not doing unequal cost load balancing
Lucas Rene
Hi everyone! New here, and i hope to be an active user. I encounter myself doing some EIGRP LABS.
The thing is i want to do some unequal load balancing, and i have two routes to reach 172.16.2.0/24 network. I type the variance 2 command (or 100, it doesnt matter) in order to do some unequal load balancing but its not showing up in my routing table... what could be the problem? Thanks in advance.
Z#show ip eigr topo 172.16.2.0/24
IP-EIGRP (AS 100): Topology entry for 172.16.2.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 156260
Routing Descriptor Blocks:
192.168.23.1 (FastEthernet1/0), from 192.168.23.1, Send flag is 0x0
Composite metric is (156260/128257), Route is Internal
Vector metric:
Minimum bandwidth is 100000 Kbit
Total delay is 5100 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 1
192.168.13.1 (FastEthernet0/0), from 192.168.13.1, Send flag is 0x0
Composite metric is (158820/156260), Route is Internal
Vector metric:
Total delay is 5200 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 2
As you can see, if i do a show ip route, there is only one route to 172.16.2.0
Gateway of last resort is not set
D 192.168.12.0/24 [90/30820] via 192.168.23.1, 00:02:33, FastEthernet1/0
[90/30820] via 192.168.13.1, 00:02:33, FastEthernet0/0
C 192.168.13.0/24 is directly connected, FastEthernet0/0
172.16.0.0/24 is subnetted, 3 subnets
D 172.16.1.0 [90/156260] via 192.168.13.1, 00:02:33, FastEthernet0/0
D 172.16.2.0 [90/156260] via 192.168.23.1, 00:02:33, FastEthernet1/0
C 172.16.3.0 is directly connected, Loopback1
C 192.168.23.0/24 is directly connected, FastEthernet1/0
CCENT
Giuseppe Larosa
Hello Lucas,
EIGRP can perform unequal cost load balancing but only with paths that satisfy the Feasibility Condition
You can check using
show ip eigrp topology all
The reported distance has to be stricly lower then the feasible distance (the composite metric as advertised by the neighbor)
The computed distance over the backup path has to be less then V * feasible_distance.
Likely for the prefix of interest you have a successor and no feasible successors, you can check this with show ip eigrp topology all
The reason the FC has to be satisfied is that in any case EIGRP wants to avoid possible routing loops  even temporary.
Hope to help
Giuseppe
