EIGRP not using fastest route
ppolando
I have a network with 5 sites. Each site has a metro ethernet connection to two providers. Here is my set up:
2821
Gig0/1
Connected to Provider A at 100Mbps full duplex and they provisioned circuit at 100Mbps
FA0/3/0 (1-port 10/100 HWIC)
Connected to Provider B at 100Mbps full duplex and they provisioned circuit at 20Mbps
interface GigabitEthernet0/1
description Consolidated Communications 100Mbps Metro E.
ip address 10.20.20.13 255.255.255.0
load-interval 30
duplex full
speed 100
appletalk cable-range 1010-1010 1010.243
appletalk zone WAN
interface FastEthernet0/3/0
description Comcast 20Mbps Metro E.
ip address 10.10.10.8 255.255.255.0
load-interval 30
duplex full
speed 100
router eigrp 1
redistribute connected
network 10.10.10.0 0.0.0.255
network 10.20.20.0 0.0.0.255
auto-summary
My router will only use the connection with Provider B. Provider B is supposed to be used only as a backup if Provider A goes down.  EIGRP works if  I pull the cable from Provider B, it will fail-over to A. I'm not an expert by any means with EIGRP, any ideas would be greatly appreciated!
chrihussey
Providing the 2821 router config might make it easier to resolve.
That aside, the G0/1 and F0/3/0 interfaces are operating at 100mbs, so the bandwidth is the same. If you configure "bandwidth 20000" (which is 20Mb) under the F0/3/0 interface you may get your desired results.
Other that that, adjusting the delay metric for each interface should fix the issue.
