Eigrp path selections
feroz syed
Level 5
Level 5
Router 5 has only one path to reach router 6 loopback address (6.6.6.6) in topology table there is no fesible sucessor.how to install all possible path to reach router 6
Router5#sh ip eigrp topology
P 6.6.6.6/32, 1 successors, FD is 156160
        via 150.0.0.6 (156160/128256), FastEthernet0/0
hello
at present there is only one successor via rtr 6 as the others are not meeting thr FC - for this to happen the need a have a reportered distance lower then the existing feasible distance of this route
this can be done by manipulating the delay vlaues of the links on the other rtrs interfaces
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
11 Replies 11
Hello
do you have alternate path to this loopback?
res
paul
Kind Regards
Paul
only one path to reach r5 to r6 via switch, but i want to use all path i mean from r5-r4-r6  r5-r2-r6 include serial interface.
R5#sh ip eigrp topology all-links
IP-EIGRP Topology Table for AS(100)/ID(5.5.5.5)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 1.1.1.1/32, 2 successors, FD is 2560002816, serno 190
        via 25.0.0.2 (2560002816/2560000256), FastEthernet2/0
        via 150.0.0.2 (2560002816/2560000256), FastEthernet0/0
        via 45.0.0.4 (2560005376/2560002816), FastEthernet0/1
        via 205.0.0.2 (2560512256/2560000256), Serial1/0
P 3.3.3.3/32, 2 successors, FD is 2560002816, serno 189
P 4.4.4.4/32, 2 successors, FD is 156160, serno 165
        via 45.0.0.4 (156160/128256), FastEthernet0/1
        via 150.0.0.4 (156160/128256), FastEthernet0/0
        via 25.0.0.2 (158720/156160), FastEthernet2/0
        via 205.0.0.2 (2300416/156160), Serial1/0
P 2.2.2.2/32, 2 successors, FD is 2560002816, serno 173
P 6.6.6.6/32, 1 successors, FD is 156160, serno 163
        via 45.0.0.4 (158720/156160), FastEthernet0/1, serno 135
        via 205.0.0.2 (2300416/156160), Serial1/0, serno 126
P 5.5.5.5/32, 1 successors, FD is 128256, serno 1
        via Connected, Loopback0
P 25.0.0.0/24, 1 successors, FD is 28160, serno 2
        via Connected, FastEthernet2/0
        via 150.0.0.2 (30720/28160), FastEthernet0/0
        via 205.0.0.2 (2172416/28160), Serial1/0
P 26.0.0.0/24, 3 successors, FD is 30720, serno 172
        via 25.0.0.2 (30720/28160), FastEthernet2/0
        via 150.0.0.6 (30720/28160), FastEthernet0/0
        via 45.0.0.4 (33280/30720), FastEthernet0/1
P 45.0.0.0/24, 1 successors, FD is 28160, serno 3
        via Connected, FastEthernet0/1
        via 150.0.0.4 (30720/28160), FastEthernet0/0
        via 205.0.0.2 (2174976/30720), Serial1/0
P 46.0.0.0/24, 3 successors, FD is 30720, serno 164
        via 45.0.0.4 (30720/28160), FastEthernet0/1
        via 25.0.0.2 (33280/30720), FastEthernet2/0
        via 205.0.0.2 (2174976/30720), Serial1/0, serno 128
P 123.0.0.0/24, 2 successors, FD is 2560002816, serno 174
hello
res
paul
Kind Regards
Paul
please not understand can you explain little brief
current routing path is
reported distance= 156160   but RD cant be decreased but can increase
Fesible distance= 128256
all other router fessible distance is 156160 are same but reported distance is higher then current distance
The reported distance is not meeting the Feasible.condition of being lower than the current feasible distance of the current route
res
paul
Kind Regards
Paul
Hello.
Just in theory (because in production we will have to answer a lot of question before) you should increase delay on R5 f0/0 by 1; this will allow other neighbors to become FS (but could affect other routing).
Hello
I wouldn't increase or decrease any delay on either rtr5/6 but decrease it on the other rtrs to make them more appealing.
However this need to be calculated has to not change the current routing path.
via 25.0.0.2 (158720/156160), FastEthernet2/0 - the composite metric and the reported distance is currently higher then the FD of the current route
If you lower the delay value on the attached rtr interface of fa0/2 this will also change the composite metric and its reported distance value to be lower
This is calculated by a default eigrp defined formula of bw & delay
Bw (lowest interface bw on route path) / 10^7
Delay / 10 (total sum on interfaces delay on route path)
= bw+delay * 256
So you need to be careful of changing any values if you are not totally confident in eigrp metric manipulation
Res
Paul
Kind Regards
Paul
Ok, if you don't want to change delay, then we could tune metric directly:
R5:
access-list 6 permit 6.6.6.6
router eigrp 1
offset-list 6 in 1 f0/0
variance 128
Helllo
Can you please explain the offset, why would it help in this situation and how do you get a varience of 128?
res
paul
Kind Regards
Paul
variance 15 can get 2342400 bycomparing serial interface reported distance
what is the use of this command ?
offset-list 0 in 1000 fa 0/0
hello
the.offset pist.you have stated.will apply an interface metric of 10000 to all routes traversing that link
the varience is for load balancing on equal and unequal eirgp routeing paths
what you originally was querying was to obtain multiple feasible sucessors not to load balance -am i correct?
Kind Regards
Paul
