EIGRP Redistribution into BGP VRF MPLS Tunnel
jebowling
I have a WAN that is terminated from BGP VRF MPLS Tunnel and I need to redistribute into EIGRP.  The ip vrf LAN  rd 2828:101 needs to redistribute into EIGRP 1 that connects on interface GigabitEthernet0/2.
GatewayXO#
GatewayXO#show ip vrf LAN
Name Default RD Interfaces
LAN 2828:101 Gi0/1.101
Gi0/2
GatewayXO#show ip eigrp vrf LAN interfaces
IP-EIGRP interfaces for process 2828
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Gi0/1.101 0 0/0 0 0/1 0 0
GatewayXO#show ip eigrp vrf LAN neighbors
IP-EIGRP neighbors for process 2828
GatewayXO#
BGPGateway#show run
Building configuration...
Current configuration : 3065 bytes
version 12.4
hostname BGPGateway
boot-start-marker
boot system flash disk2:c7200-a3jk9s-mz.124-25f.bin
boot bootldr bootflash:c7200-kboot-mz.124-25g.bin
boot-end-marker
enable password ******
no aaa new-model
ip cef
ip vrf LAN
 rd 2828:101
 route-target export 2828:101
 route-target import 2828:101
ip vrf VLAN
 rd 2828:100
interface Loopback20
 ip address 20.20.20.20 255.255.255.255
interface GigabitEthernet0/1
 description XO BGP Gateway to WAN Systems
 no ip address
 load-interval 30
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
interface GigabitEthernet0/1.100
 description description DMZ-VLAN-100 (Company Current IP Blocks)
 encapsulation dot1Q 100
 ip vrf forwarding VLAN
 ip address 64.55.218.238 255.255.255.252
 no cdp enable
interface GigabitEthernet0/1.101
 description DMZ-VLAN-101 (route to Private IPs to WEB Filter at the end of MPLS Tunnel)
 encapsulation dot1Q 101
 ip vrf forwarding LAN
 ip address 64.55.216.246 255.255.255.252
 no cdp enable
 description Connected to Cisco 6509 EIGRP 20 VLANS
 ip address 172.19.1.1 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
 no keepalive
interface GigabitEthernet0/3
 ip address 209.116.238.33 255.255.255.248
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
 no keepalive
router eigrp 1
 redistribute static
 redistribute bgp 7014 1
 network 20.0.0.0
 network 172.19.0.0
 no auto-summary
 address-family ipv4 vrf LAN
  network 172.19.0.0
  default-metric 10000 1 255 1 1500
  no auto-summary
  autonomous-system 2828
 exit-address-family
router eigrp 10
 network 172.19.0.0
 no auto-summary
router bgp 7014
 bgp router-id 64.55.218.238
 no bgp default ipv4-unicast
 bgp log-neighbor-changes
 neighbor 64.55.216.245 remote-as 1
address-family ipv4 vrf VLAN
  redistribute connected
  redistribute static
  neighbor 64.55.218.237 remote-as 2828
  neighbor 64.55.218.237 description VLAN
  neighbor 64.55.218.237 activate
  no synchronization
 exit-address-family
  redistribute static
  redistribute eigrp 1
  neighbor 64.55.216.245 remote-as 2828
  neighbor 64.55.216.245 description LAN
  neighbor 64.55.216.245 activate
  neighbor 64.55.216.245 soft-reconfiguration inbound
  no synchronization
 exit-address-family
ip forward-protocol nd
ip route 10.0.0.0 255.0.0.0 172.19.1.2
ip route vrf LAN 0.0.0.0 0.0.0.0 64.55.216.245
ip route vrf VLAN 0.0.0.0 0.0.0.0 64.55.218.237
no ip http server
no ip http secure-server
control-plane
gatekeeper
 shutdown
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password *******
 login
end
BGPGateway#
2 Accepted Solutions
How did you config EIGRP on other side?
It should be like this:
router eigrp 2828
network 172.19.0.0
no auto-summary
Masoud
Adding to my previous comment.
Make sure 6509 only connected to interface under VRF LAN. Otherwise, configuration of EIGRP may cause routing loop.
Masoud
21 Replies 21
router eigrp 2828
network 172.19.0.0
no auto-summary
Masoud
Let me clarify sides:
Side A: Is a Cisco 6509 connected to interface GigabitEthernet0/2 as shown below. It has 20 VLANS and the whole network is running EIGRP 1
#Cisco_6509
Router EIGRP 1
Network 10.0.0.0
Network 172.19.0.0
DEMARC: This router running the above configuration.
Side Z: This is the Carrier WEB Filter which is at the end of a Fortigate firewall. I do not control this side.
Since on your 6509 you have this configuration
#Cisco_6509
Router EIGRP 1
Network 10.0.0.0
Network 172.19.0.0
So you need to change the autonomous system under Eigrp. They are now in different autonomous system.
  network 172.19.0.0
  no auto-summary
  autonomous-system 2828   to  1
 exit-address-family
Maoud
The word "to" after the number is not allowed in the current Cisco IOS
GatewayXO(config-router)#address-family ipv4 vrf LAN
GatewayXO(config-router-af)# autonomous-system 2828 ?
<cr>
GatewayXO(config-router-af)# autonomous-system 2828 to 1
% Invalid input detected at '^' marker.
I am sorry for confusion.
I meant change it to 1.
  network 172.19.0.0
  no auto-summary
  autonomous-system  1
 exit-address-family
Masoud
I cannot.  I get the argument below:
router eigrp 1
redistribute static
network 20.0.0.0
network 172.19.0.0
no auto-summary
redistribute connected metric 100000000 2000 255 255 1500
redistribute bgp 7014 metric 100000000 2000 255 255 1500 1
network 64.0.0.0
network 172.19.0.0
no auto-summary
exit-address-family
GatewayXO#config t
Enter configuration commands, one per line. End with CNTL/Z.
GatewayXO(config)#router eigrp 1
GatewayXO(config-router)# address-family ipv4 vrf LAN
GatewayXO(config-router-af)#autonomous-system 1
% Changing AS not allowed - Remove Address Family instead
You need to remove address family at first and config it again.
router eigrp 1
no address-family ipv4 vrf LAN
network 64.0.0.0
network 172.19.0.0
no auto-summary
autonomous-system 1
Thanks.  I did and the Neighbor on GigE 0/2 came up but I cannot see the other VLANS
GatewayXO(config-router)#no address-family ipv4 vrf LAN
GatewayXO(config-router)#^Z
GatewayXO#
*Dec 15 14:54:19.779: %SYS-5-CONFIG_I: Configured from console by console
GatewayXO#
GatewayXO#config t
GatewayXO(config-router-af)#network 172.19.0.0
*Dec 15 14:55:21.571: %DUAL-5-NBRCHANGE: IP-EIGRP(1) 1: Neighbor 172.19.1.2 (Gig
abitEthernet0/2) is up: new adjacency
Current config looks like:
router eigrp 1
redistribute static 1
no auto-summary
network 10.0.0.0
network 172.19.0.0
auto-summary
autonomous-system 1
exit-address-family
What command do you use to see?
show ip route VRF LAN
show commands look like this.  Question is how to get the VLANs on the 6509 to come up?
GatewayXO#
GatewayXO#
Gi0/2
GatewayXO#
IP-EIGRP interfaces for process 1
Gi0/2 1 0/0 5 0/1 50 0
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 172.19.1.2 Gi0/2 10 00:12:30 5 200 0 1284
GatewayXO#
GatewayXO#
So I see the routes on the DEMARC router.  Let me go to the 6509 and see what comes up.
GatewayXO#show ip route VRF LAN
Routing Table: LAN
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 64.55.216.245 to network 0.0.0.0
64.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
B 64.0.0.0/14 [20/0] via 64.55.216.245, 18:41:50
B 64.55.218.236/30 [20/0] via 64.55.216.245, 18:41:50
C 64.55.216.244/30 is directly connected, GigabitEthernet0/1.101
65.0.0.0/29 is subnetted, 2 subnets
B 65.44.4.40 [20/0] via 64.55.216.245, 18:41:50
B 65.44.4.16 [20/0] via 64.55.216.245, 18:41:50
172.9.0.0/24 is subnetted, 1 subnets
D 172.9.1.0 [90/28672] via 172.19.1.2, 00:15:35, GigabitEthernet0/2
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
D 172.16.7.0/24 [90/3328] via 172.19.1.2, 00:15:35, GigabitEthernet0/2
D 172.16.0.0/16 [90/31232] via 172.19.1.2, 00:15:37, GigabitEthernet0/2
172.19.0.0/24 is subnetted, 1 subnets
C 172.19.1.0 is directly connected, GigabitEthernet0/2
172.18.0.0/24 is subnetted, 1 subnets
D 172.18.1.0 [90/28672] via 172.19.1.2, 00:15:38, GigabitEthernet0/2
128.1.0.0/24 is subnetted, 1 subnets
D 128.1.1.0 [90/3328] via 172.19.1.2, 00:15:39, GigabitEthernet0/2
D 192.168.250.0/24
[90/2181632] via 172.19.1.2, 00:15:39, GigabitEthernet0/2
10.0.0.0/8 is variably subnetted, 17 subnets, 2 masks
D 10.0.0.0/8 [90/31232] via 172.19.1.2, 00:15:39, GigabitEthernet0/2
D 10.1.104.0/24 [90/3328] via 172.19.1.2, 00:15:40, GigabitEthernet0/2
D 10.1.110.0/24 [90/3328] via 172.19.1.2, 00:15:40, GigabitEthernet0/2
D 10.3.101.0/24 [90/3328] via 172.19.1.2, 00:15:40, GigabitEthernet0/2
D 10.2.100.0/24 [90/3072] via 172.19.1.2, 00:15:40, GigabitEthernet0/2
D 10.3.100.0/24 [90/3328] via 172.19.1.2, 00:15:41, GigabitEthernet0/2
D 10.2.101.0/24 [90/3328] via 172.19.1.2, 00:15:41, GigabitEthernet0/2
D 10.1.102.0/24 [90/3328] via 172.19.1.2, 00:15:41, GigabitEthernet0/2
D 10.1.101.0/24 [90/3328] via 172.19.1.2, 00:15:41, GigabitEthernet0/2
D 10.1.100.0/24 [90/3072] via 172.19.1.2, 00:15:41, GigabitEthernet0/2
D 10.1.123.0/24 [90/3328] via 172.19.1.2, 00:15:41, GigabitEthernet0/2
D 10.1.122.0/24 [90/3328] via 172.19.1.2, 00:15:42, GigabitEthernet0/2
D 10.1.121.0/24 [90/3328] via 172.19.1.2, 00:15:42, GigabitEthernet0/2
D 10.1.120.0/24 [90/3072] via 172.19.1.2, 00:15:42, GigabitEthernet0/2
D 10.1.114.0/24 [90/3328] via 172.19.1.2, 00:15:42, GigabitEthernet0/2
D 10.1.130.0/24 [90/3072] via 172.19.1.2, 00:15:42, GigabitEthernet0/2
D 10.1.177.0/24 [90/3328] via 172.19.1.2, 00:15:43, GigabitEthernet0/2
D 192.168.248.0/24
[90/2184192] via 172.19.1.2, 00:15:43, GigabitEthernet0/2
209.116.238.0/29 is subnetted, 1 subnets
B 209.116.238.32 [20/0] via 64.55.216.245, 18:41:59
S* 0.0.0.0/0 [1/0] via 64.55.216.245
GatewayXO#
GatewayXO#
GatewayXO#
Which device is going to do NAT? WEB filter?
On the other end a FortiGate
This is what the 6509B Routes look like
6509_Backup#
6509_Backup#show ip route
Gateway of last resort is 10.1.100.254 to network 0.0.0.0
D EX 64.0.0.0/14 [170/514816] via 172.19.1.1, 00:21:27, GigabitEthernet9/1
D EX 64.55.216.244/30
D EX 64.55.218.236/30
D EX 65.44.4.40 [170/514816] via 172.19.1.1, 00:21:27, GigabitEthernet9/1
D EX 65.44.4.16 [170/514816] via 172.19.1.1, 00:21:27, GigabitEthernet9/1
D 172.9.1.0 [90/28416] via 10.2.100.1, 1w1d, Vlan200
[90/28416] via 10.1.130.1, 1w1d, Vlan130
[90/28416] via 10.1.120.1, 1w1d, Vlan120
[90/28416] via 10.1.100.254, 1w1d, Vlan100
D 172.16.0.0/16 [90/30976] via 10.2.100.1, 1w0d, Vlan200
[90/30976] via 10.1.130.1, 1w0d, Vlan130
[90/30976] via 10.1.120.1, 1w0d, Vlan120
[90/30976] via 10.1.100.254, 1w0d, Vlan100
D 172.16.7.0/24 [90/3072] via 10.1.120.14, 7w0d, Vlan120
C 172.19.1.0 is directly connected, GigabitEthernet9/1
D 172.18.1.0 [90/28416] via 10.2.100.1, 1w1d, Vlan200
D 128.1.1.0 [90/3072] via 10.2.100.1, 1w1d, Vlan200
[90/3072] via 10.1.130.1, 1w1d, Vlan130
[90/3072] via 10.1.120.1, 1w1d, Vlan120
[90/3072] via 10.1.100.254, 1w1d, Vlan100
D 192.168.250.0/24 [90/2181376] via 10.2.100.1, 1w1d, Vlan200
[90/2181376] via 10.1.130.1, 1w1d, Vlan130
[90/2181376] via 10.1.120.1, 1w1d, Vlan120
[90/2181376] via 10.1.100.254, 1w1d, Vlan100
D 10.1.123.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 10.1.104.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 10.1.121.0/24 [90/3072] via 10.1.100.22, 1w1d, Vlan100
D 10.1.110.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
C 10.1.130.0/24 is directly connected, Vlan130
D 10.0.0.0/8 [90/30976] via 10.2.100.1, 1w0d, Vlan200
D 10.1.177.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 10.1.102.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
C 10.1.100.0/24 is directly connected, Vlan100
C 10.2.100.0/24 is directly connected, Vlan200
D 10.3.100.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 10.1.122.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
C 10.1.120.0/24 is directly connected, Vlan120
D 10.1.114.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 10.1.101.0/24 [90/3072] via 10.2.100.1, 7w0d, Vlan200
[90/3072] via 10.1.130.1, 7w0d, Vlan130
[90/3072] via 10.1.100.254, 7w0d, Vlan100
D 10.2.101.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 10.3.101.0/24 [90/3072] via 10.2.100.1, 1w1d, Vlan200
D 192.168.248.0/24 [90/2183936] via 10.2.100.1, 1w1d, Vlan200
[90/2183936] via 10.1.130.1, 1w1d, Vlan130
[90/2183936] via 10.1.120.1, 1w1d, Vlan120
[90/2183936] via 10.1.100.254, 1w1d, Vlan100
D EX 209.116.238.32
[170/514816] via 172.19.1.1, 00:21:42, GigabitEthernet9/1
S* 0.0.0.0/0 [1/0] via 10.1.100.254
6509_Backup#
6509_Backup#
6509_Backup#
6509_Backup#
6509_Backup#ping 172.19.1.1
Sending 5, 100-byte ICMP Echos to 172.19.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
6509_Backup#
6509_Backup#show ip route VRF LAN
% IP routing table LAN does not exist
6509_Backup#
6509_Backup#
6509_Backup#
I do not have a complete view on your network so double check my commands before setting them.
6509 is supposed to get INTERNET from DEMARC and fortigate? if yes, you need to change this default route.
no IP route 0.0.0.0 0.0.0.0 10.1.100.254
    IP route 0.0.0.0 0.0.0.0 172.19.1.1
Routing is correct between 6509 and DEMARC. VRF LAN does not exist on 6509 and it is also correct. It should not be there.
