12-14-2015 04:10 PM - edited 03-05-2019 02:56 AM
I have a WAN that is terminated from BGP VRF MPLS Tunnel and I need to redistribute into EIGRP. The ip vrf LAN rd 2828:101 needs to redistribute into EIGRP 1 that connects on interface GigabitEthernet0/2.
GatewayXO#
GatewayXO#show ip vrf LAN
Name Default RD Interfaces
LAN 2828:101 Gi0/1.101
Gi0/2
GatewayXO#show ip eigrp vrf LAN interfaces
IP-EIGRP interfaces for process 2828
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Gi0/1.101 0 0/0 0 0/1 0 0
GatewayXO#show ip eigrp vrf LAN neighbors
IP-EIGRP neighbors for process 2828
GatewayXO#
BGPGateway#show run
Building configuration...
Current configuration : 3065 bytes
version 12.4
hostname BGPGateway
boot-start-marker
boot system flash disk2:c7200-a3jk9s-mz.124-25f.bin
boot bootldr bootflash:c7200-kboot-mz.124-25g.bin
boot-end-marker
enable password ******
no aaa new-model
ip cef
ip vrf LAN
rd 2828:101
route-target export 2828:101
route-target import 2828:101
ip vrf VLAN
rd 2828:100
interface Loopback20
ip address 20.20.20.20 255.255.255.255
interface GigabitEthernet0/1
description XO BGP Gateway to WAN Systems
no ip address
load-interval 30
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/1.100
description description DMZ-VLAN-100 (Company Current IP Blocks)
encapsulation dot1Q 100
ip vrf forwarding VLAN
ip address 64.55.218.238 255.255.255.252
no cdp enable
interface GigabitEthernet0/1.101
description DMZ-VLAN-101 (route to Private IPs to WEB Filter at the end of MPLS Tunnel)
encapsulation dot1Q 101
ip vrf forwarding LAN
ip address 64.55.216.246 255.255.255.252
no cdp enable
description Connected to Cisco 6509 EIGRP 20 VLANS
ip address 172.19.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
no negotiation auto
no keepalive
interface GigabitEthernet0/3
ip address 209.116.238.33 255.255.255.248
duplex auto
speed auto
media-type rj45
no negotiation auto
no keepalive
router eigrp 1
redistribute static
redistribute bgp 7014 1
network 20.0.0.0
network 172.19.0.0
no auto-summary
address-family ipv4 vrf LAN
network 172.19.0.0
default-metric 10000 1 255 1 1500
no auto-summary
autonomous-system 2828
exit-address-family
router eigrp 10
network 172.19.0.0
no auto-summary
router bgp 7014
bgp router-id 64.55.218.238
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 64.55.216.245 remote-as 1
address-family ipv4 vrf VLAN
redistribute connected
redistribute static
neighbor 64.55.218.237 remote-as 2828
neighbor 64.55.218.237 description VLAN
neighbor 64.55.218.237 activate
no synchronization
exit-address-family
redistribute static
redistribute eigrp 1
neighbor 64.55.216.245 remote-as 2828
neighbor 64.55.216.245 description LAN
neighbor 64.55.216.245 activate
neighbor 64.55.216.245 soft-reconfiguration inbound
no synchronization
exit-address-family
ip forward-protocol nd
ip route 10.0.0.0 255.0.0.0 172.19.1.2
ip route vrf LAN 0.0.0.0 0.0.0.0 64.55.216.245
ip route vrf VLAN 0.0.0.0 0.0.0.0 64.55.218.237
no ip http server
no ip http secure-server
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password *******
login
end
BGPGateway#
Solved! Go to Solution.
12-15-2015 08:37 AM
I am doing it on a backup 6509. Will actually have to setup PBR (Policy Based Routing). to send all but two VLANs to this route.
This is a very interesting problem.
12-15-2015 08:44 AM
It is simple.
Something like this. Just example.
access-list 50 deny 10.1.100.0 0.0.0.255 [except VLAN]
access-list 50 deny 10.2.100.0 0.0.0.255. [except VLAN]
access-list 50 permit 10.0.0.0 0.255.255.255 [match others]
route-map to-fortigate
match ip address 50
set ip next hop 172.19.1.1
under the interface
ip policy route-map to-fortigate
12-15-2015 08:47 AM
thanks...I have to drive 2 hrs to make physical changes and will add PBR. I will post actual after I add it.
12-15-2015 08:33 AM
Thank you so much for the help. I am trying now how to give this a 5 Star Rating.
12-15-2015 12:38 PM
You are most welcome.
Masoud
12-15-2015 07:19 AM
Make sure you can ping 6509 IP address from your router.
Ping vrf LAN [6509 IP address] it should be 172.19.1.X.
12-15-2015 06:43 AM
Adding to my previous comment.
Make sure 6509 only connected to interface under VRF LAN. Otherwise, configuration of EIGRP may cause routing loop.
Masoud
