EIGRP Routers NOT learnt
s.kanth
Hi All,
There is a DSL backup link in our WAN environment. whenever Primary link goes down , Routers are NOT learnt from Backup link. it required eigrp reset at DMVPN Hub router.
have you ever facing such kind of issues.. please let me know what factors to be checked...
Router ID got changed recently ..that I know....
Sri
5 Replies 5
Hello
You dont say how your topology is setup  for Dwvpn.
Is it a dual or single hub and spoke design?
Can you post (if applicable) your hub and possibly one of the spoke routers running config?
res
Paul
Kind Regards
Paul
Hi Paul,
it is dual DMVPN.
Configuration is attached...
HUB Router
interface Tunnel1
 bandwidth 100000
 ip address 10.33.0.1 255.255.0.0
 ip access-group testicmp out
 no ip redirects
 ip mtu 1400
 no ip next-hop-self eigrp 1
 no ip split-horizon eigrp 1
 no ip next-hop-self eigrp 10
 no ip split-horizon eigrp 10
 ip flow ingress
 ip flow egress
 ip nhrp authentication 111
 ip nhrp map multicast dynamic
 ip nhrp network-id 101
 ip tcp adjust-mss 1200
 load-interval 30
 delay 10
 cdp enable
 tunnel source GigabitEthernet0/2
 tunnel mode gre multipoint
 tunnel key 111
 tunnel protection ipsec profile ocbackupvpn shared
end
interface Tunnel14
 bandwidth 1500
 ip address 10.44.0.1 255.255.0.0
 no ip redirects
 ip mtu 1400
 ip nhrp authentication 222
 ip nhrp network-id 202
 ip nhrp holdtime 10
 ip nhrp registration timeout 5
 load-interval 30
 delay 10
 tunnel key 222
end
Spoke router
interface Tunnel1
 bandwidth 1024
 ip address 10.33.0.8 255.255.0.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 10.33.0.1 *.*.*.*
 ip nhrp map multicast *.*.*.*
 ip nhrp nhs 10.33.0.1
 delay 10
 tunnel source Dialer1
 tunnel key 111
end
useridcisco1
Which side switchovers to DSL backup, HUB or Spoke?
Switchover happens at Spoke end.
Put the following command under spoke's tunnel config.
ip nhrp registration non-unique
Musab
