backing up configuration with ios archive
mialbert
I am trying to back up the running configuration with the ios archive feature on a 1941 running 15.1(4)m4.  This is being done via scp/sftp over a site ipsec vpn to an archive server running windows server 2012 with solarwinds sftp/scp software.  The following configuration is on the 1941.
archive
 log config
  hidekeys
 path scp://username:password@ip address/$h
 write-memory
 time-period 4320
The transfer is not completing.  What i am getting with a sh archive is
Archive #  Name
   1        :Error - No space left on device <- Most Recent
   2        :Error - No space left on device
Don't know why getting this error since space is no issue on the server, or even on flash if it's referring to that.  Also getting below with debug ip scp:
: SCP: SSH Client connect failed
This could be trying to transfer through the outside interface and not the private interface for tunnel.  Tried to use the 'ssh client-interface <interface>' command to set the outgoing interface but the command would not take.  Anyone seen something similar to this
0 Replies 0
