EIGRP routing loop
mazzz
Visitor
I have the below topology in my prod environnement.
My objective was to establish EIGRP 10 between the routers and L3 core switches but,
The EIGRP between the Router and the L3 Core Switch in "Backup"/DR site is OK and functional.
But, when I activated EIGRP in "Main site" between the router (172.19.243.171) and the Core Switch (172.19.243.174) the network went down. We lost connection to the router and the site was isolated.
It seemed there was a routing loop!
I can provide details if you require.
Thank's for your help.
fbabashahi
Hi ,
at the first glance at topology in think it's about Spanning-tree , but if you show configuration of switches , i will look at it and i wish i could help you
Hello
From the CE rtrs towards the wan PE rtr's what routing protocol is being used?
When you enabled eigrp on the main site, it looks possible your internal network took precedence over your  mpls path
Kind Regards
Paul
gaston.benitez
Level 3
Level 3
Hi.
Do you have some logs from the moment of the issue?
Did you notice High CPU on the affected devices?
Is there redistribution from MPLS cloud to EIGRP? What is the protocolo? BGP?
When you lost the connection, only managemente traffic was affected or other networks were also affected?
Can you share the configs from 4 devices?
BR
Gaston
