EIGRP static route redistribution config logic?
MicJameson1
Hello.
In the below config designed to
redistribute
static routes into EIGRP...
1. What is the significance of
access-list
10 to the
route map
and the
redistribution
config? (it only has the IP address of a monitoring server. (?))
2. May you please clarify my understanding here of the EIGRP
redistribution
config logic? My understanding is that ACL 10 is what is referenced by the
route map
In this example this ACL seems to be irrelevant and ignored, in preference to the
prefix-list
Thank you.
(obfuscated)
CAT_9300_x4#sh run | s eigrp
router eigrp 1
!! (output omittted) !!
 network 172.57.0.0
 redistribute static route-map STAT_ROUTE_EIGRP
 auto-summary
CAT_9300_x4#sh route-map STAT_ROUTE_EIGRP
route-map STAT_ROUTE_EIGRP, permit, sequence 10
  Match clauses:
    ip address prefix-lists: STAT_ROUTE_EIGRP
CAT_9300_x4#sh access-lists 10
Standard IP access list 10
    10 permit 172.59.44.100  !! this is a monitoring server !!
CAT_9300_x4#sh ip prefix-list STAT_ROUTE_EIGRP
ip prefix-list STAT_ROUTE_EIGRP: 16 entries
!! (output omitted) !!
   seq 40 permit 172.56.22.0/24
Not quite. The ACL is NOT referenced in the
route-map
only the
Prefix list
is. Here is the logic:
 redistribute static route-map STAT_ROUTE_EIGRP <- this redistributes static routes but only routes referenced in the route map
route-map STAT_ROUTE_EIGRP, permit, sequence 10 <- 10 is the sequence number of the route-map not the ACL #
  Match clauses:
    ip address prefix-lists: STAT_ROUTE_EIGRP  <-this matches the prefix list called STAT_ROUTE_EIGRP
ip prefix-list STAT_ROUTE_EIGRP: <- this defines what networks are in the prefix list
   seq 40 permit 172.56.22.0/24 <- this is the network that will be matched on in the route-map
So in this case if you have 100 static routes and you issue the
redistribute static
command under EIGRP then it will
redistribute
all of the static routes configured on the device. The
route-map
coupled with either an ACL or in this case
prefix-list
will limit which of the static routes actually make it into EIGRP. Its a form of route manipulation.
Its generally better to use a
prefix list
as you can get more granular control for certain network advertisements.
-David
M02@rt37
Hello @MicJameson1,
The
access-list
10 is used in the
route map
to match specific IP addresses or networks. In this case,
access-list
10 permits the IP address 172.59.44.100, which is identified as a monitoring server.
The
route map named STAT_ROUTE_EIGRP
is configured with a single permit statement (sequence 10) that includes a match clause referencing the
The purpose of this
route map
is to determine which static routes are
redistributed
into EIGRP.
The ACL 10 is referenced by the
 route map
but in this specific example, it seems to be irrelevant and ignored. The reason for this is that the only entry in
access-list
10 permits the IP address 172.59.44.100, which is not included in the
used in the
route map
Therefore, the ACL 10 does not play a role in determining which routes are
redistributed
The
is the primary matching criterion used in the
route map
It defines a list of
prefixes
(IP networks) that are permitted or denied for
redistribution
into EIGRP. In this case, the
prefix-list
permits the IP network 172.56.22.0/24.
Best regards
route-map
only the
Prefix list
  Match clauses:
redistribute static
redistribute
route-map
prefix-list
prefix list
-David
Giuseppe Larosa
Hello @MicJameson1 ,
@David Ruess 's answer it totally correct the
route-map
uses sequence numbers for
route-map
blocks / clauses and that 10 is the default sequence number for the first block of the
roue-map
. The
route-map
invokes only the
prefix-list
and only static routes that have a match in one of the
prefix list
statement will be
redistributed
into EIGRP.
IP access-list
10 is not related to the
route-map
Hope to help
Giuseppe
