EIGRP to BGP Route-map question
Vinayaka Raman
Existing Configuration:
router bgp 65457
redistribute eigrp 1 route-map xxxx
route-map xxxx, deny, sequence 5
Match clauses:
   tag 65000 4809
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map xxxx, permit, sequence 999
Match clauses:
Set clauses:
show ip route 10.48.51.0
Routing entry for 10.48.48.0/22
New configuration to be added:
ip prefix-list IP_Route seq5 permit 10.48.51.0/22
route-map xxxx deny 6
ip address prefix-list IP_Route
Please note the prefix list does not have a correct network ID (the correct one is 10.48.48.0/22)
Can you tell me what would be the impact of inserting this route-map seq 6?
Regards Vinayak
Giuseppe Larosa
Hello Vinayaka,
The new route-map clause will be inserted after the clause with sequence 5
The matching IP prefix, if it exists, 10.48.48.0/22 will be denied from redistribution from EIGRP into BGP and a BGP advertisement for the same prefix will be withdrawn.
There shouldn't be an impact other then this
Hope to help
Giuseppe
Peter Paluch
Hello Vinayaka,
The router will silently mask the address argument in the prefix-list entry with the mask, and configure the resulting appropriate network. See for yourself:
R1(config)#ip prefix-list IP_Route seq 5 permit 10.48.51.0/22
R1(config)#do show run | inc prefix-list
ip prefix-list IP_Route seq 5 permit 10.48.48.0/22
R1(config)#
So the behavior of the route-map should be completely normal, according to its individual blocks:
  • Routes tagged with either 65000 or 4809 will be denied
  • Exact route 10.48.48.0/22 will be denied
  • Other routes will be permitted
Best regards,
Peter
