EIGRP vs OSPF
moses12315
As i have read until now (monstly through cisco books, CCNA and CCNP) those prodocols are those that are suggested for using in your network. I use EIGRP in my network since all my devices are Cisco(also the switches). My network has now around 50 nodes and in 1-2 years for now it will reach the 100. Since OSPF has the areas which i don't know if i can do that with EIGRP what do you suggest about my network.
1. Do you suggest to use OSPF since my network is increasing and use areas?
2. Can i do that with EIGRP in a similar way, for examble differnt Autonomous System number?
3. In one area or AS what's the max number of nodes we should have ?
moses
ruwhite
Level 7
Level 7
Since these are two different types of protocols, the way they scale, and their scaling properties, are completely different. With OSPF, you need flooding domain boundaries to cut down on the information in the database, and to provide places where you can aggregate. With EIGRP, topology aggregation occurs at every hop, and route aggregation may be configured anyplace, so there's no need for flooding domain boundaries.
We see EIGRP networks, in a single AS, with up to 2000 routers, so you're nowhere near any sort of "router count limit" for EIGRP. In fact, IMHO, all the ideas of how large a network should get before you "switch protocols" ignore one basic point--scaling is dependent on design, not on the protocol itself.
You choose a routing protocol because of properties involving your business needs and how well the protocol meshes with your network design and maintenance practices, not because one will scale or converge faster than some other protocol.
HTH.
Russ
noroutes4u
With proper address summarization and using stub areas, eigrp should do fine. Are you on traditional campus design or on routed access? Remember, eigrp comes free with routed access design. We have a very very very large network, using routed access, with eigrp. It's working fine.
Yes i use right ip address design and summarization. Also since most of my nodes are stub i use stub networks. I am not familiar with the terms "traditional campus design" and "routed access". Can you give me more information or link me to some information.
Thanks a lot
moses
Traditionally, you have a layer 2 trunk to your distribution and all of your access switches are layer 2. With the routed access design, all of your access switch are layer 3 and so are their connections up to the distribution. Let me send you the design docs to your email. It explains the advantages and disadvantage of both. It also breaks down the convergence time for both OSPF and EIGRP.
ruwhite
Level 7
Level 7
HTH.
Russ
