RPS2300 stuck in "in use" status with 2811
ogor
My 2811 power supply stuck in "in use" status after a power supply failure.
When I put again the 2811 power supply, the supply stay provided by the RPS2300.
#sh environment
Main Power Supply is AC
Redundant Power Supply is attached
RPS status: in use
Fan 1 OK
Fan 2 OK
Fan 3 OK
System Temperature: 29 Celsius (normal)
Environmental information last updated 00:00:10 ago
I have performed the same with 3750E no problem and have the same problem with CCME 2851 see my other post http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc02696
Many thanks in advance for your return.
Olivier
Collin Clark
Only the Catalyst E Series switch is capable of reverting back to its own power supply without rebooting. All other devices might reboot when reverting back to their own power supplies (with a manual power cycle of the RPS).
Collin Clark
