EIRGP Hellos queueing and not sending on GRE Tunnel
Paul Morgan
I have just installed a new 887 in a branch office. Two GRE tunnels are configured back to our two head office routers. Only one of the tunnels is able to send EIGRP hellos successfully and hence, one tunnel adjacency is flapping after the RTO is maxed.
Ive tried a few things but Im totally at a loss now.
I can see from debug eigrp packets that the hello is enqueued and that Hellos are received from the tunnel endpoint, but the ACK is generated and queued also. There are no access lists or nat enabled on the tunnel interface and no outbound acls in place. General NAT/PAT is set for the Dialer int.
Ive removed all crypto and any QOS although I dont think these would affect this anyway.
Bear in mind that both tunnels originate at the Dialer and one is working fine.
The SH ip eigrp neigh is shown here
EIGRP-IPv4 Neighbors for AS(****)
H   Address                 Interface       Hold Uptime     SRTT    RTO   Q  Seq
                                                              (sec)         (ms)            Cnt Num
1   172.20.80.1             Tu0               10   00:00:13    83      5000    1  1784719
0   172.21.80.1             Tu1               13   2d21h        79      474      0  1437249
Any thoughts for tshooting would be greatly appreciated.
At this point Im starting to think it could be an ISP issue?
18 Replies 18
Hello Paul,
I'm afraid this might be a new bug in 15..1 as the behaviour is strange, or it might need an additional command to fix it.
Hope to help
Giuseppe
So far the distribute list blocking seems to be holding things up.
Thanks for all the help folks.
Hello Paul,
so now you have two EIGRP stable adjacencies one per tunnel?
I consider the suggested distribute lists a workaround
Good to know it worked
This has been an interesting thread with several contributes.
Best Regards
Giuseppe
Yes - two stable adjacencies thanks. And finally a stable routing table!
