06-29-2007 08:23 AM - edited 03-03-2019 05:40 PM
We just deployed a new Internet router that is running a multi-homed BGP setup. Our company provides ICMP and SNMP performance monitoring, mostly via VPN connections.
What we are seeing is a very high rate of transmit discards. I believe these are the result of packet bursts from our monitoring servers. We are using QoS to tag our VPN and monitoring traffic and give it 1 Mbps priority. I have also tuned the buffers to eliminate buffer misses. However, the router is still discarding packets at a very high rate (12,000 per hour). This is causing quite a lot of timeouts for our monitoring systems and affects our reporting accuracy.
Does anyone have any suggestions on how to eliminate these discards. So far I haven't come up with a solution and Cisco TAC hasn't found one for me yet either.
Thanks!
Attached is a copy of the router config (with most of the Ip info cleared out). I'm also attaching a graph showing the discard rates. Again everything we've tried so far has been ineffective. I did force a failover to the AT&T T1 by shutting down the IMA group - that cut the discards in half, but we obviously can't run on our failover link full time.
06-29-2007 08:43 AM
Are discards on input or output? Because QoS seems to be one way.
Also, can this be a burst issue? Try shaping and bandwidth commands, instead of priority.
e.g. (in class)
bandwidth 1024
shape average 1024
06-29-2007 08:48 AM
I think it is a burst issue, and the discards are on output (transmit on the WAN circuits). I'll try the shaping and see what it does. Thanks!
06-29-2007 10:02 AM
Unfortunately this did not work. I cannot use shaping on an IMA group. Any other suggestions???
