Enable Ethernet port
allen-grant
I'm new to Cisco and I have a 2516 router. Does anyone know the command to make the Ethernet 0 port active?
Harold Ritter
2516-A#config t
Enter configuration commands, one per line. End with CNTL/Z.
2516-A(config)#int e0
2516-A(config-if)#no shut
2516-A(config-if)#
Hope this helps,
8 Replies 8
use the following command sequence:
2516#conf t
2516(config)#interface Ethernet0
2516(config-if)#no shut
That should bring your interface into up/down status, which you can verify with the command:
show ip interface brief
Now, obviously, you need a physical (cable) connection on the port, in order to be able to sue it...
HTH,
GP
Thanks for the help! I have one question. I'm using the router 2516 as a hub and my cable modem for access. None of my computers are getting out. Is there anything else I need to do to make the router accept my three computers and get out through the router, then the Modem? I really appreciate this. Thanks again for the help earlier. AJ
can you post the configuration of your 2516 ? It would be easiest to see what you have configured, and then suggest the necessary additions...
GP
Try not to laugh. All I did was run the router and enable the Ethernet0 port. All my computers could talk to each other. I used E1 port to connect to a DSL router, Then I connected it to my Highspeed cable modem. It worked fine, but then I wanted to eliminate the DSL router. I want to use the Cisco as a hub and use E1 port to connect to my cable modem and reach the outside world. Here's the conf's below:
Router>enable
Router#show running-config
Building configuration...
Current configuration:
version 11.1
service udp-small-servers
service tcp-small-servers
hostname Router
hub ether 0 1
link-test
auto-polarity
hub ether 0 2
link-test
auto-polarity
hub ether 0 3
link-test
auto-polarity
hub ether 0 4
link-test
auto-polarity
hub ether 0 5
link-test
auto-polarity
hub ether 0 6
link-test
auto-polarity
hub ether 0 7
link-test
auto-polarity
hub ether 0 8
link-test
auto-polarity
hub ether 0 9
link-test
auto-polarity
hub ether 0 10
link-test
auto-polarity
hub ether 0 11
link-test
auto-polarity
hub ether 0 12
link-test
auto-polarity
hub ether 0 13
link-test
auto-polarity
hub ether 0 14
link-test
auto-polarity
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface BRI0
no ip address
shutdown
no ip classless
logging buffered
line con 0
line aux 0
line vty 0 4
login
end
Router#
just so that you are aware, the 2516 does not support PPPoE or PPPoA, so you cannot connect it directly to your cable modem...
GP
GP,
I really want to thank you for all your help. Also, I wanted to tell you that how I had it hooked up...worked. I was able to connect a new computer to the router, it was to connect to the internet. I had the computers to the Cisco 2516 ethernet ports 2-4. Next, I had the LINKS router to ethernet port 1
Then I had the LINKS router to the Cable modem.
I unplugged everything and plug it all back in and now it doesn't work. It's a little frustrating when you know it works. I'm at the begging of learning about routers, so any addtional information would be helpful. Maybe a list of commands and what they mean would help.
Thanks!
--AJ
Harold Ritter
2516-A#config t
2516-A(config-if)#
Hope this helps,
allen-grant
Oh, I forgot. The lights on the router's Ethernet port were not working, but now they are but I can't get out. AJ
