entry in fib table
sarahr202
Level 5
Level 5
hi everybody!
I have few questions about the following:
switch# show ip cef vlan101
prefix next hop interface
10.1.1.0/24 attached vlan101
10.1.1.2/32 10.1.1.2 vlan 101
10.1.1.3/32 10.1.1.3 vlan 101
2.2.2.0/24 3.3..3.3 f0/1
My understanding is 3.3.3.3 is ip address of neighbor that can be reached via f0/1.
But when I look at entries:
I get confused, My question is vlan 101 is virtual interface ,thus no real device can be connected to virtual interface as it only exists in software inside the switch, how could two neighbors ,10.1.1.2,and 10.1.1.3, connect to svi vlan 101?
Usually there is one- to- one correspondence between physical interface and neighbor( adjacent switch/router).
thanks a lot and have a nice weekend!
Giuseppe Larosa
Hello Sarah,
the output is clearly of a multilayer switch that can have a mix of L3 routed physical ports and SVI like vlan101.
The sh ip cef here is telling you:
10.1.1.0/24 is the IP subnet associated to SVI Vlan 101
There are two neighbors 10.1.1.2 and 10.1.1.3 that can be reached out of L3 interface SVI vlan101.
To know what ports are the devices connected you need to usual a multi step approach
a) sh ip arp 10.1.1.2
take not of the MAC address associated
b) show mac-address-table address mac-address
in this way you have moved from L3 OSI information (neighbor is out vlan101 ) to L2 OSI information ( neighbor mac-address has been learned out L2 port x/y that is member of L2 broadcast domain with vlan-id 101)
When dealing with multilayer switches you need to move between SVIs at L3 and L2 switched ports.
A confirmation of this is provided by the output of
sh ip arp
the interface listed is always a L3 interface either an SVI or a routed port
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
sh ip arp
Hope to help
Giuseppe
Thanks alot Giuseppe!
