EOMPLS HUB AND SPOKE
bunahama_ltt
hello every buddy
can any please help me to solve the following problem:
i need to connect multiple vlan site to a hub vlan using xconnect EOMPLS i mean
VLAN 1
VLAN 2
VLAN X ====== EOMPLS VLAN 3
VLAN 4
all the vlan speak to the same VLAN X
without VPLS or it should be VPLS
i mean i need multible xconnect under the same VLAN X
thanks
mheusing
VLANoMPLS is basically a point to point solution. Looking at it at the ethernet frame level: it is an instruction for a LSR to send all dot1q frames of a certain VLAN to another LSR.
Thus you cannot setup your required Hub and Spoke solution with VLANoMPLS/EoMPLS because you can only send a dot1q frame arriving in VLAN X to ONE other LSR. This solution also does not include learning of MAC addresses, which could be used to sort frames to different VCs.
So you either could use a VPLS solution - which might be a bit of an overkill - or you could setup VLANoMPLS to a trunk from the LSR out to a router/switch and interconnect the VLANs there. It really depends on the connectivity requirements you have. Why do you need layer2 hub and spoke connectivity? Which underlying issue prevents any-to-any being a candidate?
Martin
