EoMPLS
bimckenz
Does anyone know if it is possible to do EoMPLS in GRE in IPSec in one router? It is for Layer 2 extensibility across DSL with encryption compliance.
Peter Paluch
Theoretically, it should work but there seems to be an awful lot of local processing before the resulting datagram can be sent out so I am not sure about the performance of the whole thing. As you're saying this is going to run over DSL then I suppose that PPPoE is going to be involved so the overhead will easily exceed 100 bytes.
This is my estimate on the total encapsulation overhead:
PPPoE (8) + IP (20) + IPsec (80) + IP (20) + GRE (4) + MPLS (4) + MPLS (4) + CW (4) + Payload
I am assuming a rough estimate on the IPsec encapsulation to be 80 bytes, plus two MPLS labels (transport label and per-VC label), plus a control word, in total 144 bytes. The entire datagram still must not exceed 1500 bytes to fit into the outer Ethernet frame not shown here, carried over the DSL network. This limits the Payload down to 1500-144=1356. The GRE tunnel's MTU is thus 1356+4+4+4=1368.
The configuration would be akin to this (consider this just a skeleton of how it would look like, I am not striving for a complete configuration):
crypto isakmp policy 1
 ! The usual ISAKMP Phase1 stuff
crypto isakmp key ...
crypto ipsec transform-set ESP-AES-SHA esp-aes esp-sha-hmac
crypto ipsec profile TunnelProtection
 set transform-set ESP-AES-SHA
mpls ip
mpls label protocol ldp
mpls ldp router-id Dialer0 force
interface Dialer0
 encapsulation ppp
 dialer pool 1
 dialer persistent
 mtu 1492
 ip tcp adjust-mss 1452
 ip address negotiated
 ppp chap hostname ...
 ppp chap password ...
interface Tunnel0
 mtu 1368
 tunnel source Dialer0
 tunnel destination X.X.X.X
 mpls ip
 ip address 10.0.0.1 255.255.255.0
 tunnel protection ipsec profile TunnelProtection
interface FastEthernet0/0
 xconnect Y.Y.Y.Y 1 encapsulation mpls
ip route 0.0.0.0 0.0.0.0 Dialer0 ! Default route
ip route X.X.X.X 255.255.255.255 Dialer0 ! Tunnel destination over DSL
ip route X.X.X.X 255.255.255.255 Null0 2 ! Prevent recursive routing
ip route Y.Y.Y.Y 255.255.255.255 Tunnel0 ! The PW endpoint is behind the tunnel
I strongly recommend doing performance tests before rolling out this configuration to multiple sites.
Best regards,
Peter
