equal and unqual load balance ?
biplobkhan
difference between equal and unequal loadbalance ?
1. if metric is same among the three path then it is called equal load balance ?
2. if metric is not same among the three path then it is called un equal load balance ?
Biplob
steveo123
yes, but just as a side note load balancing also depends on your routers switching mechanisim, like CEF switching /fast switching can do per packet load balancing or per destination load balancing...
