Error in RV340 LOG
cle.darsie
I'm receiving these messages from the RV340 log, could you please tell me what does that means?
<warning>kernel: [4289114.860256] <4>[WARN] [AV] DECOMP ERROR 129
<warning>kernel: [4305498.769273] <4>[WARN] [AV] DECOMP ERROR 133
That code between the  brackets are always different.
Should I be worried about it?
Thank you.
there was an identical question asked a few weeks ago, but nowhere can there be anything found that explains or decribes that specific log message, unfortunately...
Make sure you are running the latest firmware, release 1.0.02.16 .
Hi George,
Yes, i'm using the latest firmware version.
I don't know if that message is related to the fact that my access rules are blocking external access to the router.
I'm just worried if that is a problem or something else..
Thank you.
